Time code? How does that work? at DVinfo.net
Old March 5th, 2012, 11:33 AM   #1
I've got an XL H1 and it has the time code BNC on the side. Does the camera generate the code or just accept it from a code generator. I'm looking hard at DVR's and the Tascam HD-P2 has a time code port as well. It would be awesome to sync them. The Tascam isn't THAT much more expensive then the other DVR's I had been looking at. If I had to add a generator or other things though... It's not worth it to me.
Paul Owens is offline   Reply With Quote
Old March 6th, 2012, 09:08 AM   #2
Re: Time code? How does that work?
Yes - this port on the original can send or receive timecode.
The second generation "S" had the timecode built into the HD-SDI jack.
John Richard is offline   Reply With Quote
Old March 6th, 2012, 10:34 AM   #3
So, to sync my video and audio with that DVR, all I would need is a BNC cable? My XLH1 is an original.
Old March 6th, 2012, 02:00 PM   #4
Hi Paul-
Yes, assuming your recorder has a standard BNC connector for Timecode syncing/slaving, then all you need is a BNC cable.
Hope this helps,
Michael
Michael Galvan is offline   Reply
