Best advice to capture from the canon XLH1 footage at DVinfo.net
Old June 21st, 2011, 02:33 PM   #1
Hello all,
I recently shot some footage using a XLH1, recorded to mini DV tape. I recorded in HD. I now need to capture the footage. I'll be using the Canon XHA1 to capture. I need capture settings using Sony Vegas Pro (8 or 10). I'll be delivering on regular DVD. I want to be sure my raw footage matches my output to DVD. So I am not sure I should capture in 1920 X 1080 or 1440 X 1080. I don't want to lose any quality.
Any help would be greatly appreciated.
Thanks to all of you in advance.
Doug
Doug Kereszturi is offline   Reply With Quote
Old June 26th, 2011, 04:20 PM   #2
Re: Best advice to capture from the canon XLH1 footage
Good afternoon,
There are numerous threads on this already. A simple way is to capture as hd, edit, go to dvd Archetect, set properties to your Sd settings and make your dvd. I turns ouot quite satisfactory.
Oh yea, I am refering to using Sony Vegas and dvd archetect. You can down load a vegas trial if you like and it wil work.
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
