Quick insight on audio output problems if possible? at DVinfo.net
Old February 17th, 2009, 01:34 PM   #1
I am needing to get audio from the camera out to an external source via the RCA jacks on the side of the camera. I have done this before. Now....for no reason that I can see at the moment, it is not working. In either camera mode or playback mode, I am not getting any signal coming out of the analog outputs. At the moment I have no other device to verify that the audio device I am connecting to is working, except when I phyically touch the end of the RCA cable I hear buzzing though the speakers...but then I plug into the XL-H1 and nothing.
Anyone have any quick ideas? Maybe something obvious that I am overlooking?
Thanks.
Marty Hudzik is offline   Reply With Quote
Old February 17th, 2009, 06:28 PM   #2
Marty,
Could be a menu setting for output. Check the Audio output settings between 1/2 and 3/4 (page 104 Manual). Are you locked into HDV or DV for playback? HTH
Old February 20th, 2009, 02:37 AM   #3
It could also be the hardware switch on the camera located next to the BNC connector.
Erin Wiedner is offline   Reply
