Xl-H1A & Final Cut Pro at DVinfo.net
Old September 8th, 2008, 12:54 AM   #1
Hello. I have a macbook pro with Final Cut Studios and I just tried to transfer footage from my xl-h1a to my final cut and I am having some problems with it being able to read my camera. Any Suggestions on how to fix this problem? Please help. New to Final Cut and this camera that I bought about 3 weeks ago
Randy Larioz is offline   Reply With Quote
Old September 8th, 2008, 06:20 AM   #2
The probably belongs in the editing for mac thread but here are some things to check.
Usually when this happens like this it's because FCP and the camera are not playing well together.
Make sure that you're sending HDV out through firewire not a DV downconvert Make sure that you have the settings for FCP correct, you should use easy setup HDY 1080 24 (or whatever you shot in)
If you've done all of that and are still having issues explain more in depth about what is happening.
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome...
Nick Hiltgen is offline   Reply With Quote
Old September 8th, 2008, 10:17 AM   #3
Thanks I will give that a try and give an update.
Old September 8th, 2008, 05:42 PM   #4
Still not working. Is it okay to use a 6 pin to 8 pin?
Old September 8th, 2008, 10:42 PM   #5
Finally got it to work. changed around in FCP, and poof it worked. Thanks, although I shot in 1080i and some scenes are looking kinda grainy for High Def. Is that natural? Any guesses as to what might have gone wrong? Thankfully this is only test footage so it's good to nip these rookie errors in the butt now before doing a shoot for someone. Wouldn't want to embarrass myself.
Old September 9th, 2008, 06:26 AM   #6
Auto Gain = Grainy/Noisey Footage.
Keep the camera in manual and at -3 gain and you will never see it again.
Luke Tingle is offline   Reply With Quote
Old September 9th, 2008, 02:51 PM   #7
Starway Pictures
Yeah, unfortunately, the H1 is not the great right out of the box. You really gotta get into the custom presets and start tweaking. Cine Gamma. Noise reduction.
There are some really sweet presets you can download off this site. Also try Disjecta's (Stephen Dempsey) Panalook preset. Emulates the look of a DVX (a little bluer, a little more saturated) very nicely. I use this one a lot for general shooting. I create my own custom presets for narrative work.
Robert Sanders is offline   Reply
