Head cleaning for XH-A1 at DVinfo.net
Old May 30th, 2008, 07:55 AM   #1
I just purchased an XH-A1. I did quite a bit of research on the camera before I bought it but never really read anything about clogged heads. I own a Panasonic DVC 80 and have had a couple of incidents with clogged heads that were easily solved with a tape head cleaner. I have only ever used Panasonic Pro tapes in it.
I have also owned an Optura Pi for many years, run many different types of tapes through it and oddly never had a head clog.
Was I just lucky with the Pi? Is there a good brand of tape for the new XH-A1...has anyone had problems with clogged heads with this camera? If so what type of head cleaner should I buy?
Guy Shaddock is offline   Reply With Quote
Old May 30th, 2008, 04:26 PM   #2
I'm not sure what you mean by "clogged" head. Do you mean dirty head? The XL H1 heads will get dirty if you shoot for a couple of days in windy, dusty country, and may require multiple passes with a cleaning head (any brand), but no permanent problems. It is no worse than any of the previous XL camcorders. Some duct tape to seal the tape compartment door helps, too.
Steve Siegel is offline   Reply
