Dm-50 at DVinfo.net
Old April 7th, 2007, 01:36 PM   #1
Dm-50
cannot get DM-50 mic to work on XL2 no power from accessory shoe
Eric Dinehart is offline   Reply With Quote
Old May 14th, 2007, 01:38 PM   #2
No power from GL1 with DM-50
I've had the same problem with my japanese GL1. Is there any way to test if this problem is the shoe or the mic itself?
Garrett Gibbons is offline   Reply With Quote
Old May 16th, 2007, 09:08 PM   #3
garrett, i wish there was a way i will try to find out. i am shooting a wedding
in june i just wanted a cheaper shotgun mic. i returned it back to the store
thinking it was the mic.
Old May 16th, 2007, 09:35 PM   #4
Rode Videomic
Eric, thanks for the reply. I am going to try to find another hotshoe accessory to plug in and see if it's my hotshoe, as well as trying out the mic on someone else's Canon, if I can find someone carrying one around.
Meanwhile, I've investigated the Rode Videomic. It looks like a much better product and they're going for around $150. It's worth looking at.
Cheers,
Garrett
Old May 17th, 2007, 01:33 PM   #5
Forgive me if I'm teaching you to suck eggs here but, I was given a DM50 as a gift and thought it was faulty however, it only works in the accessory shoe when the audio is set to record 4 Channels/32kHz/12bit (think that's correct) and the 'normal' setting is 2 Channels/48kHz/16bits. Changed the audio setting via the menu on my XL2 and the mike then worked. Hope this helps. Mike.
Michael Graham is offline   Reply With Quote
Old May 17th, 2007, 02:26 PM   #6
That's right... the only way you can use the DM-50 mic on an XL2 is on channels 3 & 4 and only when 4-channel audio recording is enabled in the menu.
Old May 17th, 2007, 06:08 PM   #7
I've got what's called an XV1, which appears to be identical in design to the GL1. I read about the 12-bit step (though the DM-50's manual doesn't seem to mention it) but still no luck. Everything else on the camera works fine; I think either my hotshoe is bad or the Japanese XV1 won't support US GL/XL hotshoe accessories (or something like that).
Thanks for all of your posts!
Old May 17th, 2007, 07:10 PM   #8
Garrett -- on the GL / XM / XV camcorders, you don't need to active 12-bit 4-channel audio recording to use the DM-50. Could be that there's a problem with the Advanced Accessory Shoe... can you test any other AAS accessory, such as a VL-3 video light?
Old May 17th, 2007, 08:18 PM   #9
Small camera trends
I actually just got back from a fruitless tour of Costco, Best Buy, Circuit City, etc..., hoping to find either a Canon camera with the shoe or an accessory (like the video light), just so I could try both ends out with brand-new hardware and go from there. Nobody sells those things, here in suburbia! All of the cameras are smaller than my cellphone and don't have accessory shoes. I guess I'll just be waiting until I stumble across someone with a decent camera or a collection of lights and mics. Thanks for your help, guys. I appreciate it a lot!
Old May 18th, 2007, 08:23 PM   #10
Hi guys, I reorderd the DM-50 mic again. I will try it out and let you guys no if it works. thank you all for your help.
Eric,
Old May 23rd, 2007, 08:51 PM   #11
hi guys,
dm-50 mic works great now. it would help if you push the audio monitor botton a couple of times. as you can tell i am new with the xl2.
thanks again,
