Xl2 and JVC TM-1011GU Monitor at DVinfo.net
Old February 20th, 2007, 09:37 PM   #1
I own an XL2 and am interested in purchasing the JVC 1011GU field monitor to give me a more accurate view of what I am shooting. I broke out my Canon Xl2 owners manual but didn't see how an external monitor other than the monochrome can be attached to the camera. Can the monitor that I am interested in be hooked up to the camera and be used along with the view finder?
This is the link to the JVC http://www.bhphotovideo.com/bnh/cont...ughType=search
Thanks......
Currently using Panasonic AG AC160 Cameras. Editing with a custom built suite by http://www.videohardware.com running the latest Adobe Suite with Matrox.
Gary Gonsalves is offline   Reply With Quote
Old February 20th, 2007, 11:36 PM   #2
Isn't there a BNC connector on the XL2 right under the S-Video Connector? Wouldn't you just use a BNC cable?
I don't mean to sound rude, by all means that's not my intension. I'm not 100% sure, but I thought that all of the audio/video ports on the back of the camera were active when the camera was on. So, I'm half asking, and half suggesting that this would be how you would do it.
If that BNC port isn't active when you're shooting, I know the composite video is, I've used a portable DVD player as a monitor before. And if the composite video is active, I'd say that with one of these...
...you'd be able to get a signal on the monitor.
Hope this helps...
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old February 21st, 2007, 06:11 AM   #3
The BNC port on the side is active when shooting, you can use a standalone monitor, or buy an lcd which connects to the hot shoe on top of the camera if you need it to be mobile. Either one will work.
Mark
www.sharkvp.com
Mark Bournes is offline   Reply
