XL2 Filters at DVinfo.net
Old January 28th, 2007, 03:18 PM   #1
XL2 Filters
Hello! I am going to invest in a circular polarizer for the XL2. There is a local camera store that sells 77mm filters. Would these work or are there filters specially designed for the Xl2?
Jonas Scott is offline   Reply With Quote
Old January 28th, 2007, 03:58 PM   #2
They won't fit your lens. XL2 lenses all utilize filters that are 72mm in diameter.
Aside from that, you get what you pay for. The better filters are made of glass, and optically coated and won't be cheap.
Richard Alvarez is offline   Reply With Quote
Old January 28th, 2007, 05:33 PM   #3
When I wrote 77mm, I actually meant 72mm. Will the filters available for still cameras work for the XL2?
Old January 28th, 2007, 08:45 PM   #4
Canon 72mm lens filters
Hi Jonas,
If you want to compare with factory stuff, this should help:
http://www.pricegrabber.com/search_g...terid=3258556/
Regards, Michael
Michael Nistler is offline   Reply With Quote
Old January 29th, 2007, 12:47 AM   #5
A 72mm filter will fit the lens on the XL2.
I own a Tiffen 72mm circular polarizer and it fits and works fine; only trouble is sometimes when I unscrew the filter from the lens gets a bit stuck every once in a while. I found that muscling it out won't work!
--JA
Jeff Anselmo is offline   Reply With Quote
Old January 31st, 2007, 11:28 AM   #6
72 Mm
I have used B&W and Tiffen Filters with success. As the other users said it is all in the glass but also what holds the glass. The filters with plastic housing are not as good overtime especially with a polarizer.
Stuart Claggett
Canon XL2, 20x & 3x lens, Evolution G2 Wireless Mics, Rode NTG-2, manfrotto 525/516, EF adapter
Adobe Video Production Suite
Adobe Creative Suite
Canon 30D, 10D, EOS 3
Various EF Lenses (Canon, CanonL, Tamron, Sigma)
Stuart Claggett is offline   Reply
