No Signal to HDTV HELP!!!! at DVinfo.net
Old December 5th, 2006, 07:10 PM   #1
For some reason today when I plugged my XL2 into my HDTV it dosnt show a picture. Instead my TV keeps displaying "No Signal". I know the problem isnt with my TV because it is not that advance. I know I have selected the correct input. I am guessing that my XL2 isnt sending a signal out but I dont know why. Its probably a simple fix in the menu that I am over looking. Can anyone help me out.
Alan James is offline   Reply With Quote
Old December 5th, 2006, 07:15 PM   #2
Images: 1
How are you connecting it to your tv? I used to use s-video but you often have to have a live signal coming in before switching the tv to that input or else it will just ignore it.
-gb-
Old December 5th, 2006, 07:16 PM   #3
Remember that there is a tiny switch near the connectors to select which one you are using!!!!!!!!!!!!!!!!
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old December 5th, 2006, 07:22 PM   #4
I am using S-Video and I also tried it with RCA. Neither show up. I have used both in the past very easy, just plug and play. I just now downloaded the Blue Barn preset manager and played around with that for a bit then when I tried to plug my camera into the TV and look at what I just created it just displayed "No Signal". I have pluged this camera into my TV hundreds of times before with absolutly no problem. I am wondering if it has somthing to do with the preset manager, but IDK.
Old December 5th, 2006, 07:29 PM   #5
Double check all of your set-ups, it is usually operator error! At least you hope it is!
Mike
Old December 5th, 2006, 07:31 PM   #6
Never mind I just tried it with another camera I had on the same ports and it dosnt work either. My tv must have broken. You know how it is, you have a 4000$ camera and u freak out that it is the broken thing, not ur reasonably replaceable 500$ TV. :-( Hope its still in warranty.
Old December 5th, 2006, 08:15 PM   #7
Have you checked that the cable is okay?
I find that cables get trashed pretty quickly when used in the field, even in the edit suite.
Mark Sasahara
Director of Photography
Mark Sasahara is offline   Reply With Quote
Old December 5th, 2006, 08:18 PM   #8
Yeah I used 3 different cabels and none of them worked. I have now tried it with a few other devices ,DVD player, 2 cameras, VCR (Yes I have a VCR) and none of them work. Ill return the TV this weekend somtime. Thanx for the help though.
