Mixing frames rates on the same tape at DVinfo.net
Old October 31st, 2006, 08:34 PM   #1
Is there any harm in using different frame rates on the same tape? I was thinking of shooting some shots in 60i for slow motion purposes, while the rest are in 24P.
Emre Safak is offline   Reply With Quote
Old October 31st, 2006, 08:47 PM   #2
Should work just fine. Capture will stop when rate changes, but then just start again.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old November 1st, 2006, 12:06 AM   #3
Slash Rules!
You CANNOT, however, put 24P and 24P Advanced footage on the same tape.
Old November 1st, 2006, 03:05 AM   #4
Why not? I've done it. Everything came out fine.
-Roger Rosales
www.rogerrosales.com
Roger Rosales is offline   Reply With Quote
Old November 1st, 2006, 09:14 AM   #5
Slash Rules!
Really? I'll have to look at the manual again, but I swear it says you can't do it.
Old November 1st, 2006, 10:49 AM   #6
Nothing will get damaged or distroyed or changed. You may just have to watch when you capture. During capature in PP 2, if the video or audio format changes then it will stop and you can just start capturing it again in the new format.
Mike
