newbie needs XL2 video advice at DVinfo.net
Old October 2nd, 2006, 10:49 PM   #1
I have just joined the forum and need some direction. I am filming auto racing events for DVDs and have 2 Canon XL2s. I need some more cameras that will blend into XL2 footage but are less expensive. Will GL2 video look close to XL2 ?
I am shooting in TV 500 shutter with a polarizing filter and let the XL2 take care of the rest.
Should I stop buying any SD equipment, and just rent cameras until I can afford HD ?
Will the GL2s get cheap after the HD stuff is on the shelf ?
Could anyone recommend a camera for 'in car' video ? Is the Sony super HAD bullet cam good enough ?
There's some video at http://visceralvideo.com/gallery.html
Michael Conn is offline   Reply With Quote
Old October 3rd, 2006, 09:39 AM   #2
shutter at 1/500?? geezz
First off, I would bring your shutter back down to 1/60. This will give your images a smoother look (unless your going for the strobe look).To answer your question about blending the gl2 and xl2--yes. As long as you set the xl2 to 4x3, and do some manual adjustments; usually the gl2's are more saturated. Also, make sure you white balance all cameras on the same thing. If your thinking about going HD, I would say wait a little longer; because right now you have no convenient means of distrubuting HD to anyone. I would keep buying SD stuff, because the prices are much cheaper then before, and if you had HD now or anytime soon, you most likley be downconverting it to SD anyways for DVD.
http://wildlookout.com
Wes Coughlin is offline   Reply With Quote
Old October 3rd, 2006, 10:48 AM   #3
Thanks for the info Wes, because I'm about to buy 2 GL2s.
I tried 1/60 but the cars were blurry, 250 was pretty good. I'm shooting at 30p and extracting stills, too. The interlaced is smoother, but I like the idea of complete frames. Good advice on HD, I just wanted to check since my cinema buddy is drooling for a new Canon.
Old October 3rd, 2006, 12:55 PM   #4
If you are only filming in 4:3 with the XL2s then a GL2 is OK, but if most of your footage is in 16:9 then I'd advise on looking for another 16:9 camera.
At the moment I'm blending some Sony Z1/FX1 16:9 footage with XL2 16:9 footage.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply
