Live broadcasting with 2x canon XL2 at DVinfo.net
Old September 25th, 2006, 06:31 AM   #1
I am asked for live broadcasting of a rock concert. The purpose is to project on a big screen I will use one camera on stage and a second camera on a bridge.
I must have the possibility to switch from one camera to the other camera. My question is which kind of equipment do I need for this type of broadcasting? As like monitor 2x, switcher, signal receiver (wire less) etc.
Tonnie van der Heijden is offline   Reply With Quote
Old September 25th, 2006, 06:40 AM   #2
You'll need some kind of vision mixing console or video splitter, if you plan to direct the two camera operators, a talkback system is also necessary. If not you need a 'game plan' up front.
Ideally you'll want a monitor for each camera and an output monitor as well (3 in total). It's up to you whether or not you physically cable the cameras to the mixer or radio link them. My experience is that radio links are unreliable and subject to interference. So I'd reckon you want to get a couple of long video feeds such as BNC co-axial cable on long runs and take the composite output from the XL-2's into a mixer and output the mixer into the distribution amp or whatever means you have of feeding the big screens.
Good luck...
http://www.myspace.com/theeejit
Allen McLaughlin is offline   Reply With Quote
Old September 25th, 2006, 07:42 AM   #3
XL2 Live Event
Does anyone know if the XL2's auto standby feature can be disabled? I've tried to use ours for some live video feeds and without actually recording at the time, the camera shuts off by itself.
Also, for switching, if you'll be doing more things like this in the future, you might check out the Tricaster from Newtek (http://www.newtek.com/tricaster/).
Neal Metzler is offline   Reply With Quote
Old September 25th, 2006, 09:54 AM   #4
Images: 1
Originally Posted by Neal Metzler
Does anyone know if the XL2's auto standby feature can be disabled? I've tried to use ours for some live video feeds and without actually recording at the time, the camera shuts off by itself..
Yes you can. It's a menu setting. Your other option for live video work is to not have a tape in the camera.
-gb-
Old September 25th, 2006, 10:04 AM   #5
Images: 1
I've done exactly what you are describing. We used one XL2 locked down by the audio console for broad coverage and I was handheld near the stage for CU's.
We used a Panasonic MX50 switcher. As was suggested, there were three monitors at the switcher to see each camera feed and the master output (to the projector screens).
The only reliable way to feed the video is coaxial cable via the BNC output of the camera (don't forget to set the little switch next to the RCA/BNC).
We also had an intercom setup so the TD could tell us what shots to get, when our camera was going live, etc.
As I mentioned in the previous post, make sure your menu setting is for VCR STOP, not SHUTDOWN so the camera won't power down if you have tape in the camera.
Good luck,
-gb-
Old October 5th, 2006, 09:53 AM   #6
I believe the feature you are looking for to disable it can be found on page-33 of the manual..
-gb-
MotionOne Studios
http://www.MotionOne.tv
Vince Lucena is offline   Reply
