xlr and sound on xl2
i have posted a problem I have on the sound forum, but there are some things I need to know thats specific for the XL2.
I'm planning on using the xlr input to connect a shotgun and a wireless lavalier. But the thing is, i seem to be getting to much noise, even when the ports are only selected with the switches and nothing is plugged in, i get a severve amount of noise in my headphones when a tweak the levels knob. I mean, Is there something wrong with my camera or is this standard. Should i set it in a diffrent matter? whenever I change between the sources in the input selector, i get the worst noise on the "rear" then on the "front" and absolutely nothing on "audio1". Please can someone help me, I am going to production on friday I have to fix this. regards
Documentary work |
Well, I said what I'm about to say in the other thread, but I'll say it again...
Make sure it isn't just the headphones. If the noise you're hearing isn't actually being recorded to tape, then you have nothing to worry about other than getting some new headphones. Play back some stuff you've shot on some decent speakers and see if you still hear the noise. |
Sorry for having pretty much the same conversation on two threads but I'm desperate.
I recorded a clip with the cam, first i switched the front mic mode, and unplugged the mic, and then i tweaked the knobs back and forth, thus increasing the noise volume, it's hearable pretty much from 10-11 o'clock on the knobs, i did the same thing setting the camera to rear, and the noise is somewhat louder in this mode. at no point where there mics connected, but i've tried with the mics and its the same.
Documentary work |
yr gonna have to take a look inside... or get someone to do it for you. Stuff like this happens with mike inputs on all sorts of cheaper end electrical equipment these days, but shoudnt with these cameras. Get profesional help id say since youve isolated the problem.
StMichael |
#5 | |
There is also an attenuation setting in the audio menus. Make sure to check that as well. Good luck, -gb- |
