Thread Tools
Search this Thread
Soft FX filter on XL2
Hello.
Over the last couple days I've been looking into Tiffen's selection of filters. Basically, the look I want to achieve is just less sharp, more film like picture. The general consensus seems to point toward Tiffens Soft FX 3 filter... Has anyone tried this, and had good results? Or... with any other of their filters such the Pro Mist? Also, can the effect of the Tiffen Soft FX 3 be created in post? Any help, or suggestions of what type of filter to purchase would be greatly, greatly appreciated. Thanks in advance, D.C. Joseph |
I used a soft 1 'polyester' filter by http://www.leefilters.com/CPEF1.asp?PageID=92 behind the lens the other week with very satisfactory results.
If you'd like to try it out I can post you a sheet, PM or e-mail please.
http://www.myspace.com/theeejit |
I suppose any 'look' be achieved in post, but realistically, the Soft FX/3 filter cannot be emulated practically in post. I have the Tiffen Soft FX/3 and use it as often as my polarizer (which are the only the only filters I really use anyways. What's unique to the filter is how it handles highlights, and how it softens the image while still retaining fine detail.
If I were to take my footage into After Effects, for example, and duplicate the footage layer, lowering the opacity to 25-33% and adding a gaussian blur, I could get the same effect as the Soft FX filters, however, highlights wouldn't be managed the same way, and detail would also be lost where detail is critical. Personally, I'd rather save time in post by shooting as close to the look I want in-camera, then touching up the footage in post. It all comes down to what your workflow, style, and desired outcome is.
-Z- |
#4 | |
#5 | |
http://img.photobucket.com/albums/v3...ot691small.jpg http://img.photobucket.com/albums/v3...nonXL-2004.jpg http://img.photobucket.com/albums/v3...nonXL-2002.jpg http://img.photobucket.com/albums/v3...ot624small.jpg
#6 |
behind lens filter.
Thanks Allen!
I've heard of the 'behind the lens' filters on higher quality cams, but was unaware that you could find them for the XL2's... Thanks! I heard someone say something about using 'panty hose' as a behind the lens filter- i dont know if they were comparing or actually implying they used it...Anyone ever heard of that? |
#7 | |
Putting the hose behind the lens would make for fewer focus headaches for sure, but I'm not sure how to mount them without interfering with the lens' electronic connections, and I'm afraid of shorting something out or something... especially with the well-documented blown fuse issues on the XL2. |
#8 | |
I imagine you would have contact problems trying that with the XL system ?
#9 | |
The time I saw this kind of filter used, it was a ring that fit the lens space- it was in a Betacam or something... regardless- it was just the right size as to keep it from preventing connection problems... I'd be curious if it would work on an Xl-2 or modified to... |
#10 | |
That said it may be worth trying, with care. The pins may just find their way through the fabric pores, but I sure as hell ain't trying it with mine ! (lol)
