Audio Monitor Button Question at DVinfo.net
Old August 14th, 2006, 02:00 PM   #1
Just want to make sure on this.
The Audio Monitor Button controls ONLY the audio out to headphones, correct? I'm doing the famous Canon mic + wireless combo and I'm just cycling through with the Monitor Button to listen on the headphones. Is that correct?
Jamie
Jamie Baughman
Jamie Baughman is offline   Reply With Quote
Old August 14th, 2006, 02:03 PM   #2
That is correct indeed. Hope this helps,
Old August 14th, 2006, 02:03 PM   #3
Jamie
Yes, like it says it's for monitoring...
http://www.myspace.com/theeejit
Allen McLaughlin is offline   Reply With Quote
Old August 14th, 2006, 02:53 PM   #4
Thanks and sorry for the obvious question...just covering my backside!
Thanks again guys.
Jamie Baughman
Old August 15th, 2006, 01:55 PM   #5
the famous canon mic and wireless combo? please can you make it even more famous by elaborating on the set up
thanks
Ray Coy is offline   Reply With Quote
Old August 17th, 2006, 10:33 PM   #6
thanks
I think the famous combo he is referring to is the very often asked question about how to set up the audio on the XL2 to record the 4 channles of audio. These forums are practically bursting with the amount of times it has been asked and explained - so using the search function should bring you a number of detailed results. Hope this helps.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply With Quote
Old August 17th, 2006, 10:51 PM   #7
I should find the best answer to that frequently asked question and make it a "sticky."
Old August 17th, 2006, 11:02 PM   #8
My Man, that's what I've been tellin' ya.
Amen brother.
-Jon
