dance club settings - Page 2 at DVinfo.net
Old July 26th, 2008, 10:53 AM   #16
I would say have the preset ready. If it doesn't work, turn it off.
I don't have a preset for sunny/cloudy days. I would suggest going outside right now and experiment. Usually you don't need gain if it's sunny outside because there is enough light coming into the iris. Hope you're not confusing gain with the film look. Two different things. Again, with 30p use 1/60th and adjust the iris accordingly. If necessary inside/night, then uses gain...don't change the shutter speed.
Jonathan
Jonathan Kirsch is offline   Reply With Quote
Old July 28th, 2008, 04:20 PM   #17
Jonathan
Jonathan U? am going tommorrow to shoot .... i am excited !!! thanks for all your help ... i find it much brighter when i shoot with shutter set on 1/30 and darker with 1/60th ... is that right ?i like the look better with 1/30 ...why should i use 1/60? ill update you guys how it went !!!! thanks again
Canon XL2, 20X zoom and 3X wide-angle, , Sony Wireless UHFs UWP-C1 and UWP-C2 , Manfrotto 503 head on 351 tripod , Glidecam 4000 Pro w/Glidecam Smooth Shooter
Wajahat Abbasi is offline   Reply With Quote
Old July 28th, 2008, 08:26 PM   #18
I don't remember the technical reason, but I was taught that your shutter speed should be double what your frame rate is, i.e. 24p=1/48, 30p=1/60, and for some reason 60i=1/60 as well.
Anyway, it's really a matter of personal choice. But keep this in mind...you can suggest "looks" all you want, but what matters is what the client wants. If they want 1/30 with 30p, then that's what you should do. If you are the client, do what looks good to you. That's all I can say.
Good luck and let us know how it turns out.
Jonathan
Old July 29th, 2008, 09:43 AM   #19
THANKS A LOT !!! ill be going tonight ... i'll let u guys know how it went !
