White Balance Aid. at DVinfo.net
Old June 22nd, 2006, 12:24 AM   #1
White Balance Aid.
Hi,
Does anyone have one of these? http://www.expoimaging.net/products/...px?id=MTAwOQ==
They seem to be what I'm looking for, but before I order, thought I'd ask!
Thanks in advance. Mike.
Michael Cassidy is offline   Reply With Quote
Old June 22nd, 2006, 12:51 AM   #2
Never used one... I prefer oldschool warm cards... work great and EASY!
ash =o)
Ash Greyson is offline   Reply With Quote
Old June 22nd, 2006, 01:57 AM   #3
Thanks Ash. I'll take your advice.
Regards, Mike.
Old June 23rd, 2006, 09:52 AM   #4
These things, as Ash says, work great.
http://www.studio1productions.com/warmcards.htm
Cal Johnson is offline   Reply With Quote
Old June 23rd, 2006, 01:05 PM   #5
Hey,
If you wanted to get that sickly greenish light a florescent throws off...or that greenish look you see in night shots in front of a convenience store, or inside even...what would you white balance to? A very light magenta maybe? Or violet?
I'll try and look for an example of what I'm talking about...
Daniel Baker is offline   Reply With Quote
Old June 23rd, 2006, 01:12 PM   #6
This WB stuff is based on simple color theory. If you want one color, balance to its complement. Red gives green, blue gives orange, yellow gives purple, etc. In practice it's a little more complicated than that, and results can sometimes not be quite what you'd expect. But that's the basic idea. Play around and see what works.
Note that it's fairly easy to get a warm or cool look this way, but other color casts are a little harder to get right.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old June 23rd, 2006, 02:23 PM   #7
Daniel,
FYI - The "warm cards" people have a special card called a "Minus Green" card which they say "provides the perfect solution for obtaining pleasing skin tones and a more correct color balance while shooting under fluorescents. It's the fast and easy way to give your camera better color rendition in uncontrollable fluorescent lighting situations."
Regards, Ken
Ken E. Williams is offline   Reply With Quote
Old June 23rd, 2006, 03:24 PM   #8
Originally Posted by Ken E. Williams
Daniel,
Ken--I think he wants the green color cast.
-->jarrod whaley.
Old June 23rd, 2006, 10:30 PM   #9
Yeah...other way around ;)
Old June 25th, 2006, 08:31 AM   #10
If you're shooting under flourescent light (inside the convenience store), a normal white balance should give you that slightly green tint to everything. Flourescent lighting / digital video don't usually produce a great result ... unless, of course, that "sickly look" is what you are after.
For the outside night shot at a convenience store ... white balance inside the store first (to true white), then take your gear outside and start your shoot. It won't be quite as dramatic as when you're inside, but it will certainly give you that greenish overcast you are looking for. Just experiment with it before your actual shoot to make sure its what you want.
If it were me ... I'd try to balance properly to bring out natural colors under the given light and adjust to the desired color in post. But, then again, post is my favorite part of the process - most folks hate it.
Achtung! Das camera ist nicht fur der fingerpoken und mittengrabben. Ist easy schnappen der springenwerk, blowenfusen und popencorken mit spitzen sparken. Das camera ist diggen by experten only. Ist nicht fur gerwerken by das dummkopfen. Das rubbernecken sightseeren keepen das cottenpiken hands in das pockets. Relaxen und watchen das blinkenlights.
Chris Owen is offline   Reply
