Settings Request - Page 2 at DVinfo.net
Old May 12th, 2006, 08:59 AM   #16
Jubal 28
Well, the problem there is that the hand-cranked movies varied in frame rate and were often much slower than 24 fps -- 8, 12, 16, 18 . . . all were common.
But you've got the right idea -- if you use a 1/24 shutter in 24p and then speed it up 200% on a 24p timeline, you get the eqivalent of 12 fps film projected at 24 fps and it may get you the look you're seeking.
David Jimerson is offline   Reply With Quote
Old May 12th, 2006, 09:07 AM   #17
I will have to see what that looks like. I would guess 200% would be too much of a speed increase. 18fps equiv may be better.
But we seem to be straying a little from the original XL2 content
Colin
Colin Jones is offline   Reply With Quote
Old May 12th, 2006, 01:42 PM   #18
Colin after you try some of these settings suggested to you it would be great if you can post a frame grab and show us what you got.
S. di Lalla
http://www.choppertown.net
Scott Di Lalla is offline   Reply With Quote
Old May 12th, 2006, 01:50 PM   #19
That is a good suggestion Scott. Once I have played around a bit I will certainly do that.
Colin
Old May 12th, 2006, 05:52 PM   #20
Just do what I said =o)
David I respect your opinion but every professional DP I know uses 1/48 shutter to recreate the perfect film motion cadence. Cameras like the Varicam which I use quite often have a shutter off setting which is equivalent to 1/48
ash =o)
Ash Greyson is offline   Reply
