Carrying the wide angle lens on my belt? at DVinfo.net
Old April 25th, 2006, 07:36 AM   #1
I did a wedding last saturday, and I really needed to switch lenses a couple of times. I had stowed my gear on my cart, and had to move around quite a bit with just the camera.
I need to find a way to have my wa lens easily accessable so I can stop for a few minutes and switch back and forth.
I was thinking that some kind of holster attached to my belt might work. I'd like to stay away from slinging anything on my shoulder.
Anyone using anything like this or have any ideas?
Bruce Yarock
Bruce S. Yarock is offline   Reply With Quote
Old April 25th, 2006, 10:38 PM   #2
A thought
A friend of mine took a can with a plastic lid that was just bigger than his device. He made a leather wrap around for it and a leather loop for a belt. He later chucked the plastic lid and made a leather lid for it too. it was very handy. I used one for awhile but I lost it (took it off and set it down, ug.) It was a rather ingenious idea and it looked nice wrapped in leather.
DATS ALL FOLKS
Dale W. Guthormsen
Old April 25th, 2006, 11:10 PM   #3
try a fannie pack type thing..
i bought a waist belt hiking pouch that has a main compartment that a 20x xl2 lens can fit in and two smaller ones next to it. i just put it on, buckle it, then rotate it so that the pouch that would be below your back is now in front of your waist. it zippers, but since the zipper is at the top and middle, the lens will not fall out unless you were doing some major moving and shaking, although i always zip up, so to speak.
it is single wall nylon and i got it used at 'play it again sports' for $10.
the extra pouches are great too. i wear it all the time, it is dark green although most are likely black.
Gregory S. Ouellette is offline   Reply With Quote
Old April 25th, 2006, 11:12 PM   #4
clarification on my post..
the pouch size you are looking for in the front will just hold the large 20x lens. the '2 others' i mention are two smaller pouches on the belt on either side, not room for 2 other lenses in the main compartment. this way there is no scraping/dropping of anything.
Old April 26th, 2006, 02:08 AM   #5
Gregory,
Do you know where I can get one of these? Got a pic?
Bruce Yarock
Old April 26th, 2006, 02:25 AM   #6
LowePro make superb lens pouches in different sizes that fit both a backpack or belt. Galen Rowell's waist belt system pouches are also good, although the colours are a bit bright for my taste and I prefer the plain black LowePro versions.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old April 26th, 2006, 02:27 AM   #7
Thanks , Tony. Do you have a link for one that would fit either of the lenses? I calle dbh, and couldn't really get any help as to which specific pouch would be the best.
Bruce Yarock
Old April 26th, 2006, 02:40 AM   #8
http://www.lowepro.com/Products/
www.WILDCARP.com
www.NIKON.me.uk
Old April 26th, 2006, 03:08 AM   #9
Any of the smaller lens cases between 1 and 4s should fit the 3X lens and the 4 or 5 for the 16X or 20X lenses:
http://www.lowepro.com/Products/Accessories/lens_cases/
The belt or belt+harness sytems are good for attaching various pouches:
http://www.lowepro.com/Products/Belts_and_Harnesses/
The modular belt packs are also good for carrying more than just the lens:
http://www.lowepro.com/Products/Beltpacks/modular/
www.WILDCARP.com
www.NIKON.me.uk
Old April 26th, 2006, 03:09 AM   #10
Tony,
After I read your first post, I went back and found it on BH. I think this is the only one that will fit either xl2 lenses.
http://www.bhphotovideo.com/bnh/cont...&Q=&sku=153243
Bruce yarock
Old April 26th, 2006, 03:15 AM   #11
That photo is of the medium size 4 lens case. I have this one attached to my main LowePro Trekker bag. Large lenses like the 16X or 20X fit inside it with ease with room to spare, but it is too big for a waist belt. You'll need the smaller sizes if you want it just for a waist belt and smaller 3X lens.
Ooops! I'm not thinking...you'll need somewhere to place the 20X lens when the 3X lens is in use...
The size 4 is about right for the 20X lens...but I'd advise you to only use it attached to a backpack. A better idea would be to carry a backpack with your main gear + 20X lens pouch, and a separate smaller waist belt with small lens pouch with 3 X lens inside.
www.WILDCARP.com
www.NIKON.me.uk
Old April 26th, 2006, 03:17 AM   #12
Looks like the lens case 5 will fit either the 20x or the wa.
Thanks again
Btw...Those are some BIG fish.Were any of the ones you were holding up still alive?
Bruce yarock
Old April 26th, 2006, 03:21 AM   #13
The 5 says it can be used with a waist belt. Is it really too big? I need one that I can fit either lens in. For example, If I need to switch over to my wa, I need a place to store the 20x while I'm using the wa, and vice versa.
Bruce Yarock
Old April 26th, 2006, 03:25 AM   #14
The size 5 is way too big. The 4 will fit both, but still a bit big for the waist.
Regarding the fish...ALL fish were treated like babies, and all were returned to the water. The 700lb sturgeon is a protected species and would die if its weight were not supported by the water. I do not believe in killing just for the sake of taking a photo.
www.WILDCARP.com
www.NIKON.me.uk
Old April 26th, 2006, 05:19 AM   #15
Kinesis belt system
You may want to check out the kinesis belt system as well. It is for photography but of course most of it can be used for video stuff as well
Michael Salzlechner
Michael Salzlechner is offline   Reply
