Audio Playback Issue at DVinfo.net
Old April 18th, 2006, 02:18 AM   #1
Hi Friends,
I am new here and a new owner of a Canon XL2, my first professional camcorder. I am a writer by profession and have ventured into filmmaking recently. One of the first problem I have faced with the XL2 is playback of some Mini DV tapes I had shot on a Sony PD 150. The audio is not there at all though I have edited the same footage I was previewing and they had perfect audio. Please advise me further how to trouble shoot this.
Thanks.
Surya Shankardash is offline   Reply With Quote
Old April 18th, 2006, 09:28 AM   #2
Are you trying to playback the tapes while in the camera? The XL2 does not have an onboard speaker. To monitor the audio with the XL2, you will need to have a set of headphones connnected.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply With Quote
Old April 18th, 2006, 11:09 PM   #3
Problem While Playing On Tv
Hi Jonathan,
Thanks for the reply. I was trying to playback the tapes in the camera while connected to my TV with the A/V wires from the panel next to the battery. I am also confused with the audio channel settings.
Old April 19th, 2006, 09:35 AM   #4
Originally Posted by Surya Shankardash
Hi Jonathan,
I don't think I have specifically tried that method myself, but I would assume it would work fine so long as you have the input correctly set on the tv, and you are using the lower rca jacks rather than the upper ones (assuming you recorded the standard stereo 1 & 2 channels)
-Jon
Old April 19th, 2006, 08:38 PM   #5
Doesn't Work!
I confirmed all the connections were secure and proper but it still doesnt work, in fact the audio level indicator also doesnt indicate anything at all.
Old April 19th, 2006, 09:49 PM   #6
-Jon
I am not sure and the cameraperson involved is unavailable to clarify which channels have been used.
Old April 19th, 2006, 11:16 PM   #7
Images: 1
In theory any mini-dv cassette should play in any manufacturer's system Unfortunately, in the real world there are some inconsistencies. You have found one of them. Some XL-2 cameras (including one of mine) have just enough misalignment so as to not be able to playback stuff from another camera. I am sure the tape will play back fine on the Sony PD150 or several other cameras for that matter.
To verify your connections, use one of your own tapes and record some stuff on the XL2 then play it back. If you can hear audio, your connections and setup are okay.
-gb-
Old April 21st, 2006, 02:33 AM   #8
DOES MISALIGNMENT MEAN bad PIECE?
Thanks Greg, I will test a tape recorded on the same camera. One thing I would like to know is if you mean that the camera is a faulty piece when you mention misalignment.
Old April 21st, 2006, 06:46 AM   #9
Images: 1
You can send it in to Canon under warranty and theĽ will perform a head alignment. Be sure to tell them that it's because the camera can't playback material from other camera sources.
If you do send it in, be sure any tape you have shot on this camera to date is archived somewhere such as a firewire or internal hard drive. After they re-align the heads for compatibility, this camera won't play back those tapes that it recorded before.
You can find other threads here on the forum describing the exact same dilemma you are going through.
regards,
-gb-
Greg Boston is offline   Reply
