Trying to get 4 wirless lav's on my XL2 at DVinfo.net
Old February 8th, 2006, 01:42 PM   #1
Is what I need
http://img522.imageshack.us/my.php?i...achment0mm.jpg
what would the setting for channels 1&2 be once this is installed, and as far as I know, this shouldn't disrpt my normal work flow for channels 3&4, correct? (I mean 3&4 should be the same as I always do?
Chris Fritsche is offline   Reply With Quote
Old February 8th, 2006, 03:33 PM   #2
I think 2 of your mics will need to be XLR mics and the other 2 can connect using RCA. Only thing to remember is you can only monitor 2 channels at a time and you need to toggle between 1/2 and 3/4 using the audio monitor button.
PS: I can't really make out the picture you have (appears kinda small) but you shouldn't need extra devices to sue all 4 channels unless they use different connections, in which case, just get some adapters.
Andrew Khalil is offline   Reply With Quote
Old February 8th, 2006, 03:49 PM   #3
If you want to use all 4 channels of audio on the XL2 an dconnect with XLR you will need to buy the MA-300. $170 approx. However, keep in mind that when recording 4 channel audio, the XL2 records in 12bit, not 16bit. Shouldn't be that big of a deal, but just make shure that when you go to edit, that your NLE can capture and edit 12bit.
Scott Aston
Eyecon Pictures, Inc.
Scott Aston is offline   Reply With Quote
Old February 9th, 2006, 11:10 AM   #4
Any idea if FCP can do that, 4 channels of 12 bit that is?
