lens compatibility. at DVinfo.net
Old January 19th, 2006, 01:29 AM   #1
lens compatibility.
Will Canon Xl1s lenses work for the Canon XL2, and will Canon XL2 lenses work for the Canon Xl1s?
Bryan Mitchell is offline   Reply With Quote
Old January 19th, 2006, 03:50 AM   #2
Bryan, all XL-lenses will work on any XL-camcorder (XL2, XL1S or XL1) and people here in the community also says that those lenses works well on the XL-H1 as well!
You may read Chris Hurds excellent article on this subject:
http://www.dvinfo.net/canonxl2/articles/article04.php
- Per Johan
Old January 19th, 2006, 03:59 AM   #3
What specifically causes these lenses to have a different 35mm equivalent than when mounted on an XL1s? Larger CCDs?
http://www.dvinfo.net/canon/articles/article58.php
Old January 19th, 2006, 04:11 AM   #4
The XL-2 does have larger CCDs, since they are true 16:9 ratio. So, yes, there will be a discrepancy in the specs when everything else is otherwise the same.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759
Doug Boze is offline   Reply With Quote
Old January 19th, 2006, 04:29 AM   #5
Thank you to everyone for the help regarding my lens questions. I have one more, as I'm trying to get wide angle shots now. I've looked at the 3x wide angle lens, and it's a bit expensive. I've not ruled it out, but I'm looking at some adaptors (even though the articles suggest a fragility to them). My question is really about functionality.
I'm looking at http://www.bhphotovideo.com/bnh/cont...ughType=search
and
One is much cheaper than the other. I'm wondering what the difference is (beside one being 0.7 and one 0.6). Which one can you zoom through, and I can't figure out what a Bayonet Mount is.
