Less wear on heads
We have a xl2 and use a less expensive cam to transfer file to PC. If we get the XLH1 hd version can I still use the sd cam to transfer, or does it have to be hd?
Re: Less wear on heads
It will need to be either a XLH1, XHA1 or an HV30 (series of cameras). Most people used to buy an HV camera; though seemingly the wear and tear on the heads was never as bad as people were led to believe.
You could also get something to record from the HD/SDI of firewire cable as you are recording to tape (like a firestore or datavideo dn-60 for the firewire, or a nanoflash or samurai for the HD/SDI).
http://vimeo.com/channels/guerrillafilms |
Thank you so much for your help.. So if understand it must be a HD cam to up load HDV tape to My PC and NOT a SD cam
Imo grab a Canon HV40 before they disappear altogether, doubles as a B cam as well.
Read the reviews .. http://www.bhphotovideo.com/c/product/597424-REG/Canon_3686B001_VIXIA_HV40_High_Definition.html Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
#5 |
I have successfully captured tapes shot with a xh-a1 in 25f with a sony fx1000 a few years ago, then was also said you needed a canon camera to do that but to my surprise the Sony worked just as well.
#6 | |
The HV40 is the current Canon minimalist HDV camcorder, it replaced the HV30 in their line a couple years ago. The Canon HDV signal is 1440x1080. Some HDV machines may be 720p and not understand the Canon recording.
dpalomaki@dspalomaki.com |
#7 |
Thank you.. I GOT IT NOW
