what lens to get at DVinfo.net
Old September 13th, 2005, 02:23 AM   #1
what lens to get
hi,
i'm about to do a job were i need a lens that is as wide as possible.
what would be best, the 3x original canon vdo lens or to get the adapter and an ef lens. or something else? i talked to a photographer and he tlaked about some "ferm 14 lens" (thats what the guy called it, i dont know the propper name on it) this lens was for a didgital slr. i'm about to get a tele lens in a while as well so maybe the adapter for ef lenses would save up a bit but what about quality?
i chatted w. bh, but the vdo guy told me to ask the photo guys. but i thought i would try here first.
if my questions dont make sence or if it seams like i lost it please tell me.
tanks for any help
tom
Thomas Thoren is offline   Reply With Quote
Old September 13th, 2005, 02:42 AM   #2
RED Code Chef
An EF lens doesn't work for you since it is magnified 7.2 times. So a 20mm lens
would become a 144mm lens.
I would say the 3x wide angle lens would probably be the best indeed. There
are also screw on adapters for the 16x or 20x lens to convert it to a more wide
angles lens.
Rob Lohman, visuar@iname.com
Old September 14th, 2005, 07:56 AM   #3
ok thanks,
how wide,degree, %, is the 3x i only had small cameras and the screw on lenses were described in % 0.45 etc. and they all gave vinjetting. and i guess that the screw on for the 20x lens would do the same or?
i read about the info that bh gave but it was not that much just that its a 3x lens. and they had one second hand, 3x. i'm kinda spacing out here. i bought most my stuff from bh but never 2nd hand. it was listed as a 9 so that is almost new. but is it worth saving the $270?
