BNC to Coax Video Out at DVinfo.net
Old August 26th, 2005, 04:31 PM   #1
Does anyone know whether you can get a signal out using a BNC to coax adapter? I am trying to use the XL2 to run live video to a monitor in another room, and the distance from the camera to the video switchbox is too long for s-video. I thought using coax from the BNC jack would do the trick, but so far, I haven't been able to get a signal.
Any thoughts?
Mat Harris
Associate Pastor
Celebration Church
Round Rock, Texas
"Connect with your destiny."
http://www.celebrationchurch.info
Mat Harris is offline   Reply With Quote
Old August 26th, 2005, 04:41 PM   #2
I would use a BNC all the way until the last inch and then put on a BNC-RCA adapter. Tried this?
KW
Kevin Wild is offline   Reply With Quote
Old August 26th, 2005, 05:05 PM   #3
Hi Mat,
See my tip, "Make Sure the Switch is Switched" located at:
http://www.dvinfo.net/canonxl2/tips.php
Old August 26th, 2005, 05:44 PM   #4
Just how long is that run from the camera to the monitor?
James Emory is offline   Reply
