A tip on custom settings.... - Page 2 at DVinfo.net
Old July 20th, 2005, 03:45 PM   #16
Post a grab and I will see if I can get close...
ash =o)
Ash Greyson is offline   Reply With Quote
Old July 20th, 2005, 05:01 PM   #17
Ash, around here you have become the Master of custom presets.
Old July 20th, 2005, 05:24 PM   #18
Originally Posted by Ash Greyson
Here is a setting good for a grainy B&W contrasty look:
Gain: +18dB
Frame rate: 24P
Oops, actually the XL2 is limited to +12db in 24P and 30P frame rates. See the bottom of page 61 in the operator's manual. Great setting, though! Thanks for sharing it,
Old July 20th, 2005, 07:36 PM   #19
Yeah, sorry, in 24P mode it will flash +18dB and then switch to +12db
ash =o)
Old July 25th, 2005, 10:14 PM   #20
colors......
I am sometime reminded that "NTSC" is short for Never The Same Color twice;)
Dale Johnson is offline   Reply With Quote
Old August 11th, 2005, 05:46 PM   #21
Technicolor Preset
Could someone please post the settings for this? I use a Mac and am unable to download it.
TIA
Javier Urena is offline   Reply With Quote
Old August 11th, 2005, 05:54 PM   #22
Hi Javier,
Although you can't use the software, you can still download the preset file and open it with any old text editor (it is possible to open a .txt file on a Mac, isn't it)? If you can open it with a text editor, the conventional settings are in there and properly identified and you should be able to read them.
Old August 11th, 2005, 06:12 PM   #23
Thank you Chris, got it.
Old August 28th, 2005, 01:32 PM   #24
Anyone have an idea why I can't get the Bluebarn presets to load into my XL2? I have installed the program and have the presets on my computer. I plug in my camera and turn the controls to the Ext Control position. Once plugged in I get the usual "found AV/C device." I've tried both letting it go to the Internet and not allowed it to go to the Internet. Once I open the program and try to go to Preset 1, or 2 or three, the program hangs for a couple of seconds and then comes back with an error message and then completely crashes and closes. I've tried this on three XP computers...same results. I normally capture all my video through a Sony deck, not the camera and this is the first time I've plugged the camera into the computer. Could it have something to do with the necessary drivers for the camera? If so, what am I missing?
Dave M.
Dave Merrell is offline   Reply With Quote
Old October 21st, 2005, 02:45 AM   #25
Does the Presets manager work on a PAL XL2 or is it only for the NTSC version?
David
David Morton is offline   Reply With Quote
Old October 21st, 2005, 04:50 AM   #26
It's O.K. I got it working.
David
Old October 25th, 2005, 04:28 PM   #27
David how did you get it working because I have the same crashing problem? Im using the PAL version of the XL2
Steven Salmon is offline   Reply With Quote
Old October 25th, 2005, 04:46 PM   #28
Steven,
I'm not sure which David your question was directed at, but I'll field you question. I got it working after realized I wasn't allowing the driver for the Blue Barn presets to install on the XL2. After I allowed them to install, it worked as advertised.
Dave Merrell
Old October 30th, 2005, 11:47 AM   #29
let the good settings roll...
Thank you all, presets and Bluebarn software are working fine...
Fernando Cesar is offline   Reply With Quote
Old November 7th, 2005, 11:27 AM   #30
about the presets
Hello all.. this is my first post.
I have recently bought the canon xl2 and great acc.. I have been using the preset manager (really cool) and I have got these presets
Amelie.bbp (347 Bytes, 491 views)
ContrastB&W.bbp (357 Bytes, 388 views)
Documentary.bbp (344 Bytes, 437 views)
FocusAssist.bbp (350 Bytes, 376 views)
Routine.bbp (316 Bytes, 386 views)
Saturated.bbp (320 Bytes, 386 views)
Sports.bbp (323 Bytes, 394 views)
Technicolor.bbp (304 Bytes, 413 views)
Wedding.bbp (258 Bytes, 424 views)
My question is... Where can you get some more???? I have been searching but no luck... any help would be apreciated..
Also any one had any problems perfectly balancing the xl2 on the glidecam 4000??? grrrrrrrr
Travis Minchew is offline   Reply
