July 5th, 2005, 12:43 AM | #1 |
XL2 Audio ?
I am about to purchase a Canon XL2 but need answers to a couple of questions.I will be filming a documentery using an Audio Tecnica AT-897 shotgun mike.I plan to use a field mixer with headphones plus a mini disk or something similar to record backup audio. Unfortunatly I have been told that unlike the XL1's the new Canon XL2 will only take the mic and not a mixer at the XLR imputs unless I use a pad on the connecters? The sales people know nothing about this,or where I could get such a device.Does anyone have any ideas on this matter,and where I can get these pads ?
Also any suggestions on a good value for money field mixer that would suit my requirements. |
July 5th, 2005, 01:41 AM | #2 |
Joe,
This "problem" with the XLR inputs just doesn't make sense to me unless you are using a powered (amplified) mixer. If you are using a typical passive mixer, there should be no problem sending the output to the XL2 inputs. What you are doing is essentially just submixing. The only thing you'll want to do is optimize you levels (mixer output and XL2 input) in order to minimize noise. In other words, you wouldn't want to send a very low signal to the XL2 and have the XL2 gain all the way up. By the way, there is a 20 db attenuation switch (another word for a "pad") for the XL2 inputs that you'd normally use if signal coming into the mics was too hot. Thanks, Kelly
------------------------- Partial Equipment List: Canon XL2 w/ 20X zoom Bogen/Manfrotto 516 Pro fluid head Bogen/Manfrotto 3246 legs Panasonic PATC7WMS1 7" LCD PowerMac G5 2.7 GHz OS X Tiger 2 GB RAM, 400 GB SATA ATI Radeon 9600 Dell 2405FPW 24" LCD Final Cut Pro 5.0 Studio |
July 5th, 2005, 03:32 AM | #3 |
The difference is that for line in, you must use handle rca inputs in 12 bit mode, where before the XLR in on the the xl1s/xl1 was switchable from LINE to MIC to MIC ATT.
Quite useful was the previous setup when feeding to the cam from a mixer thus avoiding the inherant noise of 12 bit audio ... |
July 5th, 2005, 05:12 AM | #4 | |
Shure makes a couple of XLR inline pads, one a fixed -50db and the other switcheable for 3 different amounts of attenuation. Audio Technica also lists one, the AT8202, on their web site. I'm still in equipment selection mode myself, like you, so I don't have direct experience with them but several of the audio gurus here say very nice things about the Sound Design MixPre, 302, and 442 field mixers. |
July 5th, 2005, 07:16 AM | #5 | |
July 6th, 2005, 03:21 AM | #6 |
Thanks for your advice Kelly,Jimmy,Steve, Chris .This is the sort of information I could not get from the local supplier.
July 6th, 2005, 04:22 AM | #7 |
Also, note that the XL1/XL1s did not have built-in XLR inputs,, just unbalanced inputs. The XLR adapter was an accessory (Canons MA-100/200), or third party. Canon's XLR adapters are powered by the camcorder and limited to MIC level signals, will saturate/clip if the audio input apprached line levels (around -10 dBV).
Some mixers offer an switch controled option for mic level outputs (on the order of -30 dBU), which should be OK.
dpalomaki@dspalomaki.com |
July 6th, 2005, 04:38 AM | #8 | |
July 6th, 2005, 08:47 AM | #9 | |
I just finished a 2 cam shoot with the board feed 1/4 inch through the handle rcas in 16 bit. No noticeable noise that can sometimes occur in unbalanced audio. To restate, the ability to run directly in with XLR is preferred but as recent history has shown, the rca unbalanced line in at 16 bit resolution can produce a hum free result when conditions are good. Thanks Chris ... have fun at DVExpo ... let us know promptly the Canon plans for HDV .... |
July 6th, 2005, 08:58 PM | #10 |
Thanks again all you guys who provided information , Joe
July 7th, 2005, 12:57 AM | #11 | |
Joe, you should be able to select a "mic" or "line" level OUTPUT from your mixer. Check the switches on the output side of you mixer. Choose the 20db switch on the camera if you aren't using a mixer and the audio input levels are too high. As Kelly said, after you set your master tone level on the mixer, you should set your individual channel output level to 5 on the the mixer and your input level on the camera to 5 and then make slight adjustments on both when needed. I bought a Shure SHA15LA attenuater that cuts 50 db at B&H for $39. I am a one woman "band" and need this when I take a board feed without the benefit of a sound person with a mixer. Best wishes, Stephanie |
July 7th, 2005, 01:30 AM | #12 | |
Thanks, Kelly
July 7th, 2005, 05:56 AM | #13 | |
I'm wondering if some of the audio gurus could chime in and answer a related question I've been curious about - if you were using something like the 302 to feed a camera's mic input, which would be the better practice, to set the mixer output to mic level with the cable between the two carrying the mic level signal or to keep it at line level and insert a pad just before the camera to drop it down so that the cable between the two carried line level signals? Or perhaps phrased another way, if you were using a line level mixer to feed a mic level camera, would it be better to attentuate at the mixer end of the cable or the camera end? (Assuming balanced throughout.) I would expect the latter would give better noise immunity but I wonder if that's really true and if it would be signifigant. In the same vein, the Canon has a switchable 20 db attenuator on the input. If you figured you needed a 50 db pad, for instance, would you do it with the internal attentuator switched out and put a full 50 db attenuator in the line or would it be better to switch the internal attentuator in and add another 30 to the inbound line? Or is it likely to matter? |
July 7th, 2005, 06:53 AM | #14 |
Fred Retread
To an electronics tech, "passive" means no amplification. If it consumes power from any source, it ain't passive. A "Y" connector would be an example of a passive mixer.
Regarding attenuation placement, or the amplitude of the signal over the most of the length of the run, in my humble technical estimation there can be a difference, but it is not likely to be significant in balanced runs. Induced noise, as we know is cancelled. Noise developed in resistors and connectors becomes part of the signal, and its percentage is constant before and after the signal is stepped down. That all says, "no difference." But at the points where resisitive and/or contact noise is generated, that's not linear. Higher voltages will dilute at least resistive noise. I'm not so sure about contact noise, that's a fluky phenomenon. So if human life or the freedom of my grandchildren were at stake, I'd go for higher signal level over the run. That being said ('cause obviously I like to talk and I have summers off), like you I'd defer to the voice of experience.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge "My brain is wired to want to know how other things are wired." - Me |
