Eyepiece adjustment -- more possible? at DVinfo.net
Old March 11th, 2005, 02:09 PM   #1
I have just been reviewing some footage I shot with the 16x manual lens and some of it seems just out of focus to me.
I wear bifocals and remove them for shooting. It appears that the diopter adjustment in the XL2 eyepiece is just short of what I need to focus properly and that may be the reason for the problems I am having. Is there any way to change the range of adjustment?
I supposed this could also be a back focus problem. Given the eyepiece adjustment issue, I wonder if I could set the back focus properly in anycase?
Peter Wiley is offline   Reply With Quote
Old March 12th, 2005, 09:25 AM   #2
RED Code Chef
Keep your glasses on? For backfocus adjustment you should
follow the 16x manual on this matter.
Rob Lohman, visuar@iname.com
Old March 12th, 2005, 10:30 AM   #3
No guarantee that you will be successful but you could try taking the camera to your optician and asking him to cut a blank that would slip in under the eyepiece rubber with the same power as your eyeglasses.
Old March 14th, 2005, 04:15 AM   #4
Peter,
I also wear bifocals and in some situations I think its difficult to focus through the eyecup.
Lifting up the eyecup looking direct into the viewfinder screendisplay helps me alot!
- Per Johan
Per Johan Naesje is offline   Reply
