BIG Problem at DVinfo.net
Old February 24th, 2005, 10:44 PM   #1
BIG Problem
I'm suddenly getting problems playing back my DV tapes on my XL2.
Has anyone seen this problem before ?
Here is a grab:
http://home.comcast.net/~chalbers/problem.jpg
Can I fix it or do I need to return it ?
I just got it 3 weeks ago .
Frank
Frank Aalbers is offline   Reply With Quote
Old February 24th, 2005, 11:56 PM   #2
Looks like dirty heads. The camera manual says to clean the camera as soon as you get it. Did you do that by chance? Your camera is probably fine, but your shot...is shot. No fixing the tape.
Good luck.
Kevin
Kevin Wild is offline   Reply With Quote
Old February 25th, 2005, 01:10 AM   #3
It does ? What page ?
Anyway , the shot is not shot. It was recorderd OK, it just plays back wrong now. Used to play back OK. I'm going to clean the head tomorrow with a cleaner tape and see what happens. That's also what Canon support suggeted !
Thanks for the input.
Frank
Old February 25th, 2005, 10:53 AM   #4
Sorry, can't give you page number, but it's there.
Oh yeah...glad it was the playback head that was dirty and not the record head...thus, your tape is fine.
Old February 25th, 2005, 03:49 PM   #5
By the way, what is the best way to clean the heads on the XL2?
Ed Bicker is offline   Reply With Quote
Old February 25th, 2005, 08:53 PM   #6
<<<-- Originally posted by Kevin Wild : Sorry, can't give you page number, but it's there.
Oh yeah...glad it was the playback head that was dirty and not the record head...thus, your tape is fine. -->>>
Oh ! I didn't know there wher 2 seperate heads. !
Frank
Old February 26th, 2005, 06:42 AM   #7
RED Code Chef
<<<-- Originally posted by Ed Bicker : By the way, what is the best way to clean the heads on the XL2? -->>>
With a DV cleaning tape?
Rob Lohman, visuar@iname.com
Old February 26th, 2005, 09:18 AM   #8
Page 32 under the section for preparing the camcorder, top of the page;
BEFORE YOU BEGIN RECORDING
Make a test recording first to check if the camcorder operates correctly. If necessary, clean the video heads. pg110
ON page 110 they reccomend cleaning the heads frequently. They also reccomend NOT USING WET TYPE head cleaners.
I use the Pannasonic dry head tape cleaner.
Richard Alvarez is offline   Reply With Quote
Old February 26th, 2005, 11:56 AM   #9
I must have an updated version of the manual.
It DOES talk about cleaning using NOT wet type cleaners, but on my page 110 it doesn't mention ANYTHING about BEFORE YOU BEGIN RECORDING.
Oh well ... I can only go on Monday to fix the problem. This weekend is taken for me.
Thanks for all the great info !
Old February 28th, 2005, 11:22 PM   #10
So yes ! Using the cleaning tape ( Panasonic dry cleaning tape might I add ) fixed the problem.
I'm going to stay with Pana DV tapes from now on. Probably the MQ series. Just to keep it safe.
Thanks for all the help and feedback on this issue !
Frank
Old March 2nd, 2005, 06:19 AM   #11
Frank,
It is page 32 that tells about cleaning if the XL2 doesn't work correctly and it refers you to page 110.
On page 110 it does recommend cleaning frequently, however, cleaning tapes are abrasive. Personally, I would only run the cleaning tape when I noticed artifacting or the "Heads dirty, use cleaning cassette" message appears. "Frequently" is a pretty subjective term.
Dan
Wow! That thing must have cost an arm and a leg! - - - It did! I used to have three of each.
Dan Mumford is offline   Reply With Quote
Old March 2nd, 2005, 01:14 PM   #12
Cleaning Tape
The problem with this is that when you notice artifacts, well, then the footage is ruined. Also, this kinda assumes you are reviewing the tape fairly soon after whooting as compared to shooting several tapes and then editing later
<<<-- Originally posted by Dan Mumford : Frank,
Dan -->>>
David Levine is offline   Reply With Quote
Old March 2nd, 2005, 01:31 PM   #13
Re: Cleaning Tape
<<<-- however, cleaning tapes are abrasive. -->>>
This is a bit amusing comment: Back in 97 when my XL1 was brand new, one friend of mine wanted to borrow the camera for a weekend. I forgot the cleaning tape into the case. Now, this friend of mine thought it was just an ordinary tape and recorded half an hour of material to the cleaning tape. Then he rewinded the tape and tried to monitor his footages and fast forwarded the tape several times. After the weekend when returning the camera he told me there may be something wrong with it.
Obviously, I was concerned that the video head was damaged, but now several years later, the video head still creates perfect images and it has lasted much longer than the nominal life cycle. So, perhaps the warning of abrasive cleaning tapes is only meant to protect the producer of the tapes (if somebody uses them like ordinary tapes).
Lauri Kettunen is offline   Reply
