How robust is the signal of the XL2? at DVinfo.net
Old December 15th, 2004, 08:54 PM   #1
Hi there
I am considering using the XL2 to shoot a dramatic TV series, it's my first choice btw this and the Sony Z1U. However, an HD expert here told me that the signal on the XL2 is easy to break i.e. if you shoot aimed at the end of a long runway, or if you shoot horizontal lines at an angle (his exact test was to shoot venetian blinds with the camera rotated to an angle).
Have you guys experienced anything like this, where you get the 'jaggies' or artifacting under less than idea shooting conditions or even non-conventional shooting?
Thanks.
Ronald Lee is offline   Reply With Quote
Old December 15th, 2004, 09:22 PM   #2
Ronald, its signal is as "robust" as any other standard definition DV camcorder. How would it be any different?
Old December 15th, 2004, 11:07 PM   #3
What he meant was that if you tilter the camera, or shot straight lines at weird angles, or converging lines, that you can 'break' the signal, meaning get artifacts or jiggies or whatever.
I've seen similar stuff happen on my PDX10, I'm just hoping on he XL2 it's not a major problem, but rather a negligiable one.
Old December 16th, 2004, 08:07 AM   #4
Yes, you will get "jaggies" with the XL2 or any other video camera unless the manufacturer has incorporated a blur (antializasing) filter which reduces the vertical resolution sufficiently. As "sufficiently" would result in an appreciable reduction of vertical resolution and as the situations where jaggies are annoying are relatively infrequent most manufacturers do not incorporate a strictly band limiting filter though good cameras apparently do have some. I do not know whether Canon has an optical antialiasing filter nor, if they do, where it cuts but it is apparent it does not attenutae high frequencies enough to completely suppress aliasing from near horizontal lines.
At http://homepage.mac.com/ajdel/FileSharing5.html you will find a file "XL2 Samples" which is DV straight from the camera. In about the middle of the file there are images of some Zapotec pyramids the one of which closest to the viewer shows aliasing between courses of stone at the edge of the lowest platform. It's quite obvious and you should have no trouble spotting it if you are looking for it. At nominal viewing distance I doubt you would even notice it but you will have to judge for yourself whether it is major or negligable. Be sure to look at the clip on a studio monitor or, if on a computer, that the pixel size of the display is 720 x 480 or some integer multiple of this unless you are confident that you graphics card does interpolation properly. This is to insure that you see the aliasing of the XL2 - not the display system!
Old December 16th, 2004, 08:59 AM   #5
I have had extreme difficulty shooting outside. The camera seems to have a hard time with grass, leaves, trees, etc. While it is true that most cameras do have these problems they seem to be more pronounced with the XL2. However I have found some workarounds for these issues although it is a pain.
Kevin Kocak is offline   Reply With Quote
Old December 16th, 2004, 07:23 PM   #6
<<<-- Originally posted by Kevin Kocak : I have had extreme difficulty shooting outside. The camera seems to have a hard time with grass, leaves, trees, etc. While it is true that most cameras do have these problems they seem to be more pronounced with the XL2. However I have found some workarounds for these issues although it is a pain. -->>>
Do you think this camera could be controlled so that the above problems don't happen, with careful shooting? Is it safe for broadcast and professional use (meaning these problems can be controlled?)?
Old December 17th, 2004, 12:33 PM   #7
<<<-- Originally posted by Kevin Kocak : I have had extreme difficulty shooting outside. -->>>
Kevin, could you be more specific. I shoot all the time outside and have not observed any problems. The only problem which comes into mind is that the viewfinder is not able to show "grass, leaves, trees" etc. properly, but the signal recorded on tape is just perfect. Could it be that you talk of what you see on the viewfinder?
Lauri Kettunen is offline   Reply With Quote
Old December 17th, 2004, 01:12 PM   #8
Barry Wan Kenobi
There are limits to the abilities of DV compression, well-documented, especially as related to high-frequency detail (such as grass and leaves). There's not much the camera can do about it, as it's the compression that's unable to cope, not the camera itself.
That said, many people don't notice a problem. Those that do will see blocking and mosquito noise artifacts, things like that around areas of very high-frequency detail.
Old December 17th, 2004, 01:34 PM   #9
I use a NTSC 8" and you can see artifacting on it. I have done some experimenting and found it can be reduced but not eliminated. Don't get me wrong, I love my XL2. There are going to be different problems with different cameras. You have to know the limitations of the medium you are working with and how to make it work for you... That is what makes a good shooter.
To answer your question Ronald NG... You can definitely achieve broadcast quality. You can't possibly expect a camera to produce the perfect image for you all the time. You have to use the camera and its settings to capture the image you want. Also just watch tv for a while, specifically reality tv and you can always find a moire or artifacting.
Old December 17th, 2004, 01:37 PM   #10
"Jaggies" and stair-stepped lines are more of a limitation of the DV format than the camcorder.
Old December 17th, 2004, 01:48 PM   #11
Indeed DCT based compression like DV has its limits w.r.t artifacts (not in subjective resolution), and most people don't "see" them. What is recognized more often is what A.J.deLange pointed out : optical aliasing on the CCD level. Not only in the vertical direction but also horizontally. These problems are often masked by the CCD motion blurr on sharp moving edges. On the contrary these effects become worse with high shutterspeeds and high detail settings. "Jaggies" have a simular origine but are seen in non moving pics. In near horizontal structures there is additional interline flicker produced with interlace pics. Consumer cams sum up (weighted) individual pics (and lines) for their ''optical'' filtering, pro cams use real (birefringence based)sharp optical cut-off filters.(Li-niobate)
Andre De Clercq is offline   Reply With Quote
Old December 18th, 2004, 04:32 AM   #12
<<<-- Originally posted by Andre De Clercq : ... w.r.t artifacts (not in subjective resolution), and most people don't "see" them. -->>>
as well, many like me may consider the artifacts as a fact of life.
Besides, the question is not only of the DV format. For example, when they broadcast the formula one races in live, especially from the helicopter view, the sides of the track (the border between the black track and the red-white side region) are quite badly stair-stepped. With a fairly limited number of horizontal lines such things just appear.
