1/25th shutter speed = half resolution? at DVinfo.net
Old November 17th, 2004, 09:10 AM   #1
Shooting at 1/25th shutter speed on 25p PAL will give more motion blur BUT will cut the resolution?
TIA,
Asa
Asa Phelps is offline   Reply With Quote
Old November 17th, 2004, 09:24 AM   #2
Re: 1/25th shutter speed = half resolution?
<<<-- Originally posted by Asa Phelps : Shooting at 1/25th shutter speed on 25p PAL will give more motion blur BUT will cut the resolution?
TIA,
Asa -->>>
It should not cut the resolution. In theory. Unless Canon did something "whack" here it should still be full resolution.
Marty Hudzik is offline   Reply With Quote
Old November 17th, 2004, 09:25 AM   #3
I don't think so.
Are you asking if you film at a 1/25th shutter speed you loose half of your resolution? No, I'm actually pretty sure that isn't so.
Mathieu Ghekiere is offline   Reply With Quote
Old November 17th, 2004, 09:27 AM   #4
You mean, the spatial resolution depended on the shutter speed? If so, this is not the case. The spatial resolution is constant for all shutter speeds. But as you say, longer shutter speed imply the objects in motion appear less sharp.
Lauri Kettunen is offline   Reply With Quote
Old November 17th, 2004, 09:32 AM   #5
RED Code Chef
Welcome aboard DVInfo.net Asa!
Rob Lohman, visuar@iname.com
Old November 17th, 2004, 09:43 AM   #6
I remember that with XL1 has been said shooting at 1/25th would have cut in half the resolution..
Maybe was just the blurring effect of the slow shutter that made objects appear less sharp
Asa
Old November 17th, 2004, 10:36 AM   #7
Indeed Asa, besides motion blurr (when there is motion in the pic) in 1/25 (1/30) mode and lower, your cam just outputs only one of the two fields. the field is being repeated to form an interlaced frame. So you get only get 50% vertical resolution.
Andre De Clercq is offline   Reply With Quote
Old November 17th, 2004, 04:08 PM   #8
Asa, maybe you mean (or you've heard) shooting in the frame mode (fake 25p), which on the XL1 meant losing resolution. But 25p on the XL2 is true progressive, meaning you won't lose any resolution. The XL2 uses true progressive scan CCDs, not the XL1.
David Lach is offline   Reply With Quote
Old November 17th, 2004, 04:59 PM   #9
Barry Wan Kenobi
On the PD150 and other interlaced cameras, yes using a slower-than-field-rate shutter speed would cut the resolution in half.
On the DVX (and presumably the XL2) you still keep full resolution, even as low as 1/6 of a second.
Old November 17th, 2004, 05:17 PM   #10
Could well be indeed that cams which have proscan mode also keep their resolution in slower- than-FIELD-rate shutterspeeds
Old November 17th, 2004, 08:51 PM   #11
Barry Wan Kenobi
Right -- sorry for the wrong word, I changed it to avoid confusion.
