My First XL2 Short... - Page 4 at DVinfo.net
Old December 1st, 2004, 07:23 PM   #46
I liked it immensely. I respect the amount of work that went into the making(especially getting your lady to agree to being filmed al fresco). I kinda invision a bit of a different soundtrack for it though. The lead reminds me more of a private investigator coming home from a trying case, so I hear a jazzier 40's style private dick movie sound for it...but thats just me. Keep on keeping on.
AJ Silverman is offline   Reply With Quote
Old December 1st, 2004, 08:51 PM   #47
I'm a private investigator in my day job...
No, honest, I am.
You're right, but I know what's coming next. ;) Whether or not it actually works is another thing...
THANKS!!!!!!!
Matt
Matthew Cherry is offline   Reply With Quote
Old December 2nd, 2004, 12:29 PM   #48
Matthew, you really want to shoot 2:3:3:2 for any kind of projection, digital or film. You want to keep your images clean (no diffusion filters or other smoothing techniques, because when blown up on a big screen it'll already soften), and you want progressive scaning all the way, without the resolution loss, that would occur if you had to deinterlace your 3:2 footage to edit it in 24p and project it in 24p.
So shoot 24p 2:3:3:2, edit in a 24p timeline by removing the fake frame (pull up) and when you're finished, you'll have the option to either keep it 24p for projection purposes or applying a 3:2 pull down for interlaced output such as TV.
David Lach is offline   Reply With Quote
Old December 2nd, 2004, 12:58 PM   #49
Michael Pennington
Posts: n/a
Xl1
Can the Xl1 do the same thing as the XL2 with regards to the 24fps?
Old December 2nd, 2004, 01:07 PM   #50
If you mean shooting 24fps, no the XL1 can't.
It can only shoot in normal mode, and frame mode. The lather is 30 fps per second, or if you live in PAL land where I live, 25fps per second.
Although you have a slight resolution loss, although that ain't much.
Mathieu Ghekiere is offline   Reply With Quote
Old December 2nd, 2004, 01:11 PM   #51
Michael Pennington
Posts: n/a
Then...
For a better film look would you suggest the dvx100a or the xl2?
Thanks for the info.
Old December 2nd, 2004, 01:32 PM   #52
See was that so hard? THANKS DAVID!!!
Michael,
There are huge debates regarding the DVX and XL2 when it comes to "film look". If you would prefer to grab the highest resolution standard DV image you can in native 16:9 and tweak the color in post, the XL2 is the ticket. If you would rather have the look that the DVX produces in Camera without doing much in post, get the DVX. Both are wonderful cameras. Even though I bought the XL2 I am VERY impressed with the DVX.
Matt
Old December 2nd, 2004, 01:38 PM   #53
Michael, Matthew is right. And I won't go in a too long debate about wich camera, because if you look in the XL2 forum or just perform a search here you will find a lot discussions about which one to choose and I'll think you'll find a lot more info there than I can give you.
In short: many people like the dvx100a cinema settings... a lot! The XL2 has also such a thing but there are still many people who still prefer the DVX.
The XL2 is sharper, has real 16:9 and has an interchangible lens system. If that matters to you (your options are a lot bigger, but it costs a lot, those options) then go for the XL2.
Price thag is a big difference. I think the DVX has a price thag from around the 3500 dollars, the XL2 5000, of 4500 I don't just know.
But there are many many differences, please do a search, I think you'll be happy to find all that information there.
But, as Chris (Hurd) here almost always says: pick up both in the shop and try and look what you like the most.
Good luck!
BTW: the XL2 still has the frame mode to, but with full resolution. Although I don't think many people will still use that if they have 24p.
Old December 2nd, 2004, 06:12 PM   #54
To add to what I wrote above, you have to make sure before shooting 2:3:3:2 that your editing software will in fact recognize the footage as 24p with a pull down so that it can automatically remove the fake frame for 24p editing. I know Premiere Pro 1.5 and Vegas do it, but I do not know about FCP. Something to check out before doing the shooting. You wouldn't want to be stuck with 2:3:3:2 footage with nothing to edit it on (in the way it was intended to). At the very worst, you can buy the DVFilm Maker software, which costs $150 and is designed to remove the fake frame and make a true 24p Quick Time sequence you can then edit in your NLE software for 24p footage shot with the 2:3:3:2 mode on either the DVX-100 or the XL2.
Old December 2nd, 2004, 09:17 PM   #55
Michael Pennington
Posts: n/a
Hey Matthew
Quick question for you, what lighting kit did you use for your movie?
Old December 3rd, 2004, 03:47 PM   #56
Lowel DV Creator 55 Light Kit
Old December 4th, 2004, 02:04 AM   #57
<<<-- Originally posted by David Lach : To add to what I wrote above, you have to make sure before shooting 2:3:3:2 that your editing software will in fact recognize the footage as 24p with a pull down so that it can automatically remove the fake frame for 24p editing. I know Premiere Pro 1.5 and Vegas do it, but I do not know about FCP. Something to check out before doing the shooting. You wouldn't want to be stuck with 2:3:3:2 footage with nothing to edit it on (in the way it was intended to). At the very worst, you can buy the DVFilm Maker software, which costs $150 and is designed to remove the fake frame and make a true 24p Quick Time sequence you can then edit in your NLE software for 24p footage shot with the 2:3:3:2 mode on either the DVX-100 or the XL2. -->>>
Once you turn 2:3:3:2 footage to 24p , what do you sabve it in ? Since DV codec (good quality) can't handle 24p. What is a good quality codec to keep the 24p footage in for editing ?
Thanks !
Frank
Frank Aalbers is offline   Reply With Quote
Old December 4th, 2004, 05:56 AM   #58
Great job
Hey, I'm late to the game on seeing your short. Sorry! My comments are similar to others who posted, but I will say it's refreshing to see something with "style". Usually, I watch people's first shorts and their a rip-off the latest thing or an attempt to do "Star Wars" for about $7.50 in budget!
Anyway, I like seeing shorts like yours...they're actually watchable! Oh, and don't listen to modern day Hollywood studios...B&W is awesome.
Murph
Christopher C. Murphy
Director, Producer, Writer
Christopher C. Murphy is offline   Reply With Quote
Old December 4th, 2004, 06:06 AM   #59
RED Code Chef
Re: Nice work Mathew
<<<-- Originally posted by Michael Pennington : I do have a question though, if you shoot in 24p 2:3:3:2 for projection, what if you want to take that same footage and export to DVD? Would you loose anything? -->>>
No, since DVD's can be 24p as well. So you load the 2:3:3:2
footage in your 24p project in the NLE and then output a 24p
MPEG2 file and author it in 24p.
Rob Lohman, visuar@iname.com
Old December 4th, 2004, 01:00 PM   #60
Re: Re: Nice work Mathew
<<<-- Originally posted by Rob Lohman : <<<-- Originally posted by Michael Pennington : I do have a question though, if you shoot in 24p 2:3:3:2 for projection, what if you want to take that same footage and export to DVD? Would you loose anything? -->>>
MPEG2 file and author it in 24p. -->>>
When you create a 24p mpeg and author it to DVD. Will the resulting DVD file be 3:2 pulled down data , or will the DVD player do that ?
Thanks !
