Thread Tools
Search this Thread
#16 |
Thanks for the comments
The fact that the pieces are made of metal is a plus. Seems like a worthwhile investment for $129.00.
Thanks! |
#17 | |
You may disagree with me anytime my man! Problem is I did not make that statement. Ha Ha----:) Mike
Chapter one, line one. The BH. |
#18 | |
But that's just my opinion for the reasons stated in my post above. Mainly the 4 screw plate mounting to the bottom of the camera for structural integrity. Less likely to strip out than the single 3/8 hole with a camera as heavy as the XL2. -gb- |
#19 |
Cool! Now I understand. But if that is your only concern, why not just drill 4 holes in the standard plate? Not hard at all!
Mike
#20 | |
Oh, almost forgot. A really big advantage is that the base plate part has several screw holes along the length allowing you to choose a mounting point which results in a more neutral balance. Very helpful with the nose heavy 20X lens attached. And finally, while you and I may have the right tools and ability to accurately drill 4 countersunk mounting holes, many here probably don't or won't. -gb- |
#21 |
Don't get me wrong Greg, I'm not disagreeing with you. The plate is very nice. But, I still think it is not too good for the 501, as it only adds to the weight problem. I had a 501 before going to 503s. Pans will be fine if locked down on the tilt. If it were me, I would spend that money for upgrading to a 503 first.
But, that's just my humble opinion. :) Best of luck to all. Mike
