#16 |
Check out Chris' link again, it should be listed as #1.
7 Inch LCD Monitor with VGA, Touch Screen (619GL-70NP/C/T) |
#17 |
<<<-- Originally posted by Clifton Cline : Check out Chris' link again, it should be listed as #1.
7 Inch LCD Monitor with VGA, Touch Screen (619GL-70NP/C/T) -->>> But is this the one that Lawrence Stevens actually bought? Chris makes reference to this model but then says he prefers the panasonic as it has underscan. I don't get the impression that he actually has this model or even used it. I am trying to find out exactly which on lawrence is actually using as when I search Ebay I get some different brands. Thanks, |
#18 |
You're right - I do not have the Lilliput model precisely because I could not verify that it had an underscan feature. I am less concerned about sharpness for focusing purposes as I prefer to use a tape measure to check my focus.
The Panasonic model fits most closely with cost and usage for me and while I don't own that one yet - I suspect I shall in the next few weeks. |
#19 |
<<<-- Originally posted by Chris Mills : You're right - I do not have the Lilliput model precisely because I could not verify that it had an underscan feature. I am less concerned about sharpness for focusing purposes as I prefer to use a tape measure to check my focus.
The Panasonic model fits most closely with cost and usage for me and while I don't own that one yet - I suspect I shall in the next few weeks. -->>> Chris, I am guessing you are either using the manual lens or some variant or the Mini35. There would be no practical way to use a tape measure with the stock len that I know of. |
#20 |
12v battery
In regard to the 12 v battery from best buy: it's the Vector pocket power recharchale portable battery, goes for about $30.Look in the automotive section. They sell fast
#21 |
Hi guys
I have just got back from holiday and have had no internet access for a week! The lilliput screen I bought does not have an underscan feature, however it is cheaper than the panasonic, and I think it is great. As regards to the battery. Basically all these screens take a 12V input via a pretty standard adaper/jack. What you need is a lead acid battery (like a mini car battery) with a 12V output. These basically can provide a constant current for quite a while, and may last a few hours. You are looking at the Amp Hours of the battery So you want something like 12V with 1.2 Amp Hours. That means it will drive a 12V device that draws 1.2Amps for an hour (assuming the battery is 100% efficient) The lilliput screen draws about 0.6-0.8Amps, so the spec of the battery mentioned above will power it for roughly 1 - 1.5 Hours. I velcro tha battery to the back of the screen, so it is one complete unit. Basically to make it work you need the battery, the jack and a wire that connects the battery to the jack (that then goes into the screen) JUST MAKE SURE you do not get the polarity wring. Look at the mains adapter for the lilliput screen a a reference, as you could cause the screen to permantly not work! This company is in the UK, but it is where I got my batteries from (and the connectors) http://www.maplin.co.uk/Module.aspx?ModuleNo=27088&TabID=1&source=15&WorldID=7&doy=31m10 Have a look around the site Good Luck! Lawrence
Canon XL2 Vinten Vision 3 tripod Own Build High End PC with RT.X100 |
#22 |
What about a way to mount the Monitors to the camera. What are people buying to achieve this?
DBK
Darren Kelly |
#23 |
I use a little bracket that can tilt and swivel and slides into the hot shoe. It can be adjusted for any viewing angle.
Sometimes, I'll clamp it to the tripod if I need the monitor to be remote from the camera - when using a track for example. Robin |
#24 |
So the lilliput monitor that has the higher res is easy to judge focus on? That is my main concern. Try as I might I cannot always tell 100% for sure if I am in focus on the little 2" LCD/EVF. especially in 16x9 where it gets even smaller. A lot of my shooting environments do not allow me to take a CRT field monitor with me. SO I would really like a hi res LCD without paying the big bucks for the panasonic.
#25 |
You will never find the perfect monitor.
If you find it's not right for you you can always re-sell it on ebay (as I mentioned previously) and lose around $10 for trying. Also for attaching to the xl2, I found the metal bracket you fit to the back of the camera great! Just stick velcro to the surface facing the rear, and you can velcro the back of the monitor to it. It is even roughly at the right angle for the screen!
#26 |
<<<-- Originally posted by Lawrence Stevens : You will never find the perfect monitor.
If you find it's not right for you you can always re-sell it on ebay (as I mentioned previously) and lose around $10 for trying. Also for attaching to the xl2, I found the metal bracket you fit to the back of the camera great! Just stick velcro to the surface facing the rear, and you can velcro the back of the monitor to it. It is even roughly at the right angle for the screen! -->>> I wasn't asking if it is perfect. BUt wanting your opinion on being able to use it to focus. Is it better than the LCD/EVF on the XL2? As good as the LCD on the DVX? OPinions are always welcomed. I won't hold them as fact! THanks! |
#27 |
The viewfinder on the xl2 is pretty good
I would say this is even better It is worth it :) Lawrence
