#16 |
Would XL2 owners just take a minute to see if your camera does this? If you angle the viewfinder up at little bit I find its more prominent. It does not do this as much in 30p and not at all in 60i.
#17 |
I dont see any flicker at all.
www.digitalfx.tv |
#18 |
imma look again in a dark room... brb
#19 |
okay check it... this is what i came up with... when you looking at it straight on, you won't be able to see the flickering...even when you switch modes... the VF lcd does not flicker in 4:3 mode... in 16:9 mode however, if you look at the lcd with the VF flipped up and at an angle, you'll see the flickering (only on the letterboxed black bars... the image itself is perfectly fine) and i also notice that it flickers on both top bar and bottom...only at an angle though...
lets try and figure out if this is normal... maybe it's the underscan thing?? |
#20 |
Kevin, you described it perfectly. That is exactly what is happening with mine. And like you said, I wish we could find out fast, if it's normal or not, because I'm running out of time before I can send it to B&H for a fresh one.
j. |
#21 |
shouldn't canon replace it for you... isn't that what the one year thing is all about??? warranty???
#22 |
One would hope at least. I don't doubt Canons dedication though. I'm sure if it really is a bug that Canon will do something about it.
I wonder if the Canon guy that was talked to (Earlier post) checked the viewfinder from odd angles in 16:9? If not he probably wouldn't have seen the flicker as described by Kevin..... |
#23 |
ok,
if I stand on my head and lean 20 degrees left, every time I blink my eyes mine flickers.
www.digitalfx.tv |
#24 |
Aaron. I was on the phone with the guy at Canon, while he was looking in the VF ...and I described to him about looking in the VF from different angles. He could not detect anything at all.
And kevin, It just seems like sending it to Canon would be more of an ordeal. I would rather have a fresh camera, than a fixed one. ..Ofcourse, if Canon cant fix it, I know they'll send a new one. But it just seems like it would take along time for me to get it back. ... j. |
#25 |
Kevin..John...not happening on mine...you aren't sitting under some flourescent lights when doing this are you? When you say you've got to open the viewfinder to see it that would lead me to some environmental factor...regardless...it's not happening on mine (viewing under skylight).
Barry |
#26 |
Barry. It wasnt near any flourescent lights, in my case. I walked around the entire house, and it was the same. Also, I notice the flicker with the VF both ways, up and down.
j. |
#27 |
Interesting... wish I had one to experiment with ;).
Sorry about that John. I didn't notice that you were the one who had spoken with the Canon guy. Guess I should go back and check these things before posting! Barry, How would Flourescent lighting cause flicker? I don't doubt that it could - don't get me wrong. I just don't understand the physics behind it. |
#28 |
<<<-- Originally posted by John Wheeler : And kevin, It just seems like sending it to Canon would be more of an ordeal. I would rather have a fresh camera, than a fixed one. .. -->>>
Most warranties would not entitle you to this, since your camera becomes "used" the moment you open the box. This is not to say that your vendor wouldn't exchange it for a new one as a courtesy, but I'd be surprised if they were obligated to do so because of one defect... |
#29 |
aaron--not sure that it could...but flickering can be caused by things being out of phase..both flourescent lights and the signal being fed to the LCD have a certain frequency...so when kevin described this is as being visible only when the LCD is open...I just wanted to rule out that their could be something external causing it...doesn't sound like this is the case.
barry |
#30 |
When I was playing with a couple of XL2s at the WEVA expo, I don't recall seeing any kind of flicker. Mine will be here Thursday. I'll let you know more then.
