XL2 dimensions at DVinfo.net
Old July 19th, 2004, 12:12 AM   #1
XL2 dimensions
Does anyone know the dimensions of the XL2 relative to the Xl1s, I was wondering if it will fit into my existing case? (with and without the 20x lens)
Jeffrey Hogan is offline   Reply With Quote
Old July 19th, 2004, 09:41 AM   #2
Depends on the case. It won't go into the reflective aluminum "steal-me" Canon cases but it will fit in the Kata, Petrol and PortaBrace XL1 soft shells.
The dimensions are:
(W x H x D): 8.9 in. x 8.7 in. x 19.5 in. (225mm x 220mm x 496mm)
Weight, body only: 5.3 lbs (2.4 kg)
Weight, equipped: 7.8 lbs (3.5 kg)
Hope this helps,
Chris Hurd is offline   Reply
