Timecode at DVinfo.net
Old October 1st, 2008, 06:13 AM   #1
Timecode
Can anyone help me to understand timecode. Is it like a counter on a player that it really doesn't exist? I once saw timecode actually on a VHS tape. Tell me its purpose and how to use it.
Please forgive my ignorance.
Any help would be greatly appreciated.
Frank
Frank Compoccio is offline   Reply With Quote
Old October 1st, 2008, 06:38 AM   #2
Start here.
Time code - Wikipedia, the free encyclopedia
Richard Alvarez is offline   Reply With Quote
Old October 1st, 2008, 08:46 AM   #3
Thanks but I need to know about it more extensively like what I posted.
Old October 14th, 2008, 09:35 AM   #4
Hi Frank,
Sounds like your confusion is between the systems internal timecode (not visible) as opposed to the timestamp that's burned into the actual video display. The timecode is typically used to syncronize multiple recording devices (cameras, audio recorder, etc), a great time-saving device when lining up media streams in post production.
Regards, Michael
Michael Nistler is offline   Reply With Quote
Old October 14th, 2008, 10:48 AM   #5
Frank, your request was pretty broad - so I sent you to a good source which would get you started, and allow you to follow links wherever your interest might lie.
Timecode that you saw on a vhs, MIGHT have been whats called a 'window dub'. THere is no way to answer your question, with the information you provided - so any answer would be pure speculation, and perhaps counterproductive to the purpose of your inquiry.
A window dub, is a 'burned in window' that illustrates the SOURCE TIMECODE that might be captured on that particular tape. The timecode in the small window represents the timecode of the original SOURCE TAPE, not the running timecode of the actual VHS tape that you are watching. Therefore its possible to watch a VHS of a program, with timecode in a window, where the timecode JUMPS forward or backward when a cut is made, indicating where that particular clip exists on a given original source tape.
OR - It could actually BE a reference timecode that someone overlaid on an original VHS dub, for reference purposes.
No way to tell from your questions.
You will have to give specific questions, if you want specific answers.
Old October 15th, 2008, 08:40 AM   #6
Basically, it's the counter for the Hours:Minutes:Seconds:Frames of a videotape (whether it's MiniDV, Beta, DigiBeta, SxS, P2, whatever)...all these formats have that timecode. That way, when editing, there's a standard that editors can use to locate a specific frame, scene, etc. on the tape.
How the timecode "counts" frames differs whether you're NTSC, PAL, Drop-frame or non-drop-frame.
That's the really short, BROAD definition.
Jonathan Kirsch is offline   Reply With Quote
Old October 15th, 2008, 12:26 PM   #7
Using Free Run Time Code as an External
Sync Substitute for XL2 Multi-Camera Shoots
XL2 Free Run Time Code as an External Sync by Chris Hurd
