Camera Default setting (Custom areas) at DVinfo.net
Old November 26th, 2007, 01:29 PM   #1
I have a simple questions. I am currently learning about the custom presets on the Xl2. However, most of my shots in the short 5 weeks of ownership have been with out any custom presets.
When I just pick up the camera and shoot in Non CP/manual mode what are my default presets? For Gamma, knee, black etc...
What is the camera doing in those cases?
Guy Godwin is offline   Reply With Quote
Old November 28th, 2007, 09:54 AM   #2
I hoped somebody with more experience would have helped you,
but better something then nothing, I think.
So I (as a newbee myself) will try to answer you.
The default setting are:
Gamma: Normal
Knee: Middle
Black: Middle
Color Matrix: Normal
Color Gain: You see the square in the middle of the line
Color Phase: You see the square in the middle of the line
R Gain: You see the square in the middle of the line
G Gain: You see the square in the middle of the line
B Gain: You see the square in the middle of the line
V Detail: Normal
Sharpness: You see the square in the middle of the line
Coring: You see the square in the middle of the line
Setup Level: You see the square in the middle of the line
Master Ped: You see the square in the middle of the line
NR: Off
You will get a plain picture, nothing wrong with it, but depending on what you want.
Just play with the different settings, I did it with my big screen TV as external monitor.
Easier to see what happens...
I hope this is a little bit an answer to your question.
If not, you better wait for the pro's...
Thijo
Thijo van Beek is offline   Reply With Quote
Old November 28th, 2007, 09:24 PM   #3
I may try that one.
So we can adjust the default setting's then? For some reason I could not find that in the menu. Maybe it was the late night oil that was being burnt. I will try it agan.
I assume when the defaults are set that is where the camera is at all times until changed..
Old November 28th, 2007, 10:08 PM   #4
OK - I just went back trhough the menu and manual. I did not see any area where I can adjust these items unless I have a CP selected and then I can adjust that CP. Which is fine, I just want to know that I can or can't make these changes in NON CP mode.
Old November 28th, 2007, 11:45 PM   #5
But that's just exactly what a Custom Preset is... a change from the default settings.
Old November 29th, 2007, 07:27 AM   #6
It makes sense.
I just wanted to make sure I was not missing something.
