XL2 Audio improvement at DVinfo.net
Old October 31st, 2007, 08:04 AM   #1
Hello folks,
I just bought an XL2 last week. Of all the questions that I have lets get what I believe to be the easiest out of the way. My wife loves the picture but can stand the sound. I basically, need to turn my TV up to about 50 for us to hear any thing. I assume the XL2 has an audio setting that will let more sound into the camera.
Does anyone know how to adjust this sensitivity?
thanks!!
Guy Godwin is offline   Reply With Quote
Old October 31st, 2007, 08:17 AM   #2
I haven't used the XL2 myself, but when I had my XL1, you could just change the audio levels on the side, in those controls, I think. If not, it was in the menu. But it certainly wasn't hard to find.
Using an external microphone is the best idea, but I doubt it should be SO bad if you don't-- should be not great quality, but shouldn't be so low.
Daniel Ross is offline   Reply With Quote
Old October 31st, 2007, 08:20 AM   #3
Moved from Open DV to Canon XL2.
Hard to answer without knowing specifically how you had the camera set up. The microphone that was included with the cam is more than adequate. Sit down with the operator's manual and make sure that all audio settings are on full automatic and it should take care of itself.
Old October 31st, 2007, 09:41 AM   #4
Make sure the mic attenuator is not on, that could be causing the quiet sound. It's a little switch inside the door that covers all the audio controls.
Ryan Chaney is offline   Reply With Quote
Old October 31st, 2007, 07:29 PM   #5
Thanks for the direction. I will check it out.
Old October 31st, 2007, 08:11 PM   #6
Guy, just to let you know, that you may encounter pros out that tell you this is really bad advice, as is using any "automatic" setting. However, the XL2 does well on auto, and this is especially true for audio. I shoot on full manual mode, but will often leave the audio on automatic, even for "professional" shoots. I find that the manual mode for audio on the XL2 tends to be a bit deceiving, as the meter makes it look like your getting a stronger level than you really are. When you have a chance, switch back and forth between auto gain, and manual gain for your audio, and watch the meter. Notice how high the levels read without peaking on auto mode, and it will give you an idea of where you want to be if you're using manual mode. When I first got my XL2, my manually recorded audio tended to be quite low in post.
Also, be aware of how loud any background noise is. If you're getting a lot of background noise (you can see a pretty good level even when the person you're shooting isn't talking), you'll want to adjust your shooting setup to help compensate for this. For instance, use an off camera mic instead of the on-board shotgun, or move the camera closer to your subject.
Good luck, and I hope you love your camera as much as I love mine!
Bert Smyth is offline   Reply With Quote
Old November 4th, 2007, 12:14 PM   #7
Absolutely with you, Bert. Automatic can work out fine.
I am sometimes just a one person crew on some smaller corporate shoots, particularly interviews, and just don't have the capacity to keep a check on everything that's going on. I wouldn't dream of anything but fully manual on the video side but for audio I think the auto setting works nicely most of the time. However, I rarely use the stock mic and I do spend some time carefully placing/concealing a shotgun or lavalier.
Ian . . .
Ian Stark is offline   Reply With Quote
Old November 4th, 2007, 02:58 PM   #8
So far, the autolevel on the XL2 hasn't let me down. For the most part, I use the stock mike with a fur windcover. It's usually just me, so I don't have time to ride the gain control for audio. I've used the autolevel with a shotgun mike, and again had no problems dealing with wildly varied sound levels.
That hasn't stopped me from replacing audio tracks with stuff I recorded with my MicroTrak and having to loop dialog when there was something in the background I didn't want (airplanes, mostly).
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old November 7th, 2007, 10:20 PM   #9
This was the fix...thanks!
