Presets:Blue Barn Error at DVinfo.net
Old October 18th, 2007, 11:25 PM   #1
Hey guys
I was hoping someone knows how to fix this issue - I have installed the Blue Barn Presets Manager and when I load, for example, the wedding preset - I then go to Preset # 1 and then an error message comes up - then it closes down. I also tried picking the preset # first then loading the file but it still comes up with the error message as soon as I pick a preset.
This what the error message reads:
Run-time error '-2147467259 (80004005)':
Automation error
Unspecified error
Thanks guys
Prashanna Jayaseelan is offline   Reply With Quote
Old October 19th, 2007, 11:46 AM   #2
I think this same error popped up on my screen once after installing it a while back.
connect the camera to the computer and turn it to EXT CONT. on the dial. NOW open the program and i think you should be able to load the presets w/out the error popping up. keep in mind that you must connect the camera before opening the program.
I'm at work right now so I can't really know for certain if this is the solution but please try it and let me know if it works..
Andre Guevara is offline   Reply With Quote
Old October 19th, 2007, 05:15 PM   #3
No go
Hey thanks for the tip, but that still did not work - I uninstalled Blue Barns now and then reinstalled it but the pop screen that asks for the directory for the driver does not come up, i think thats b/c the computer has already recognized the camera - so the installation wizard doesn't come up. Any ideas on how to fix this problem?
Old October 19th, 2007, 09:29 PM   #4
Windows Update
Hey guys I even did the windows update to my PC and the error message still pops up when i select a preset # - any other suggestions guys? how do you install the driver if the wizard does not pop up?
