Wide angle Lenses for XL2 at DVinfo.net
Old August 31st, 2007, 09:58 AM   #1
What kind of adapter do I need for a panasonic wide angle lenses 16:9 to be attached to my xl2?
Scott Delish is offline   Reply With Quote
Old August 31st, 2007, 02:50 PM   #2
Scott, could you specify the Panasonic lens better?
Are you talking about a Wide Angle adapter or a lens? A Wide Angle adapter with 72mm threaded mount could fit in front of the 20x lens but be aware that you most often will get a soft picture.
I know this has been discussed in previous threads here in the forum, have you done any search?
As I told you in another thread even a wide lens for DSLR will be a huge telephoto lens by using the ef-adapter which magnify with a factor of 7.8 on the XL2.
The only suitable wide lens I know for the XL2 will be the Canon 3x wide lens: http://www.bhphotovideo.com/bnh/cont...arch&Q=*&bhs=t
- Per Johan
Old August 31st, 2007, 03:28 PM   #3
It's the panasonic ag-la7200
Old August 31st, 2007, 04:14 PM   #4
Scott, I don't think this will be a good choice for you! This is a Anamorphic Lens Adapter read the quote from B&H below:
Widescreen Recording
When attached to the AG-DVX100 or the AG-DVC80 the lens adapter will allow for the highest quality 16:9 aspect ratio recording. Higher quality than even the in-camera LETTERBOX or DIGITAL SQUEEZE functions. The converter compresses the horizontal aspect of the image fitting a greater width view onto the CCDs. When viewed on a conventional 4:3 monitor, the image will appear stretched vertically. When viewed on a 16:9 monitor, the image will be a true widescreen picture.
Link: http://www.bhphotovideo.com/c/produc...s_Adapter.html
Canon XL2 already record in 16:9 wide, so why would you want to use this adapter then?
I think other adapters will suit you better, I haven't used any, so I will not recommed, maybe someone else will?
- Per Johan
Old September 1st, 2007, 01:01 AM   #5
Scott - I use the 0.6x Century Optics WA adaptor
http://www.schneideroptics.com/ecomm...=1385&IID=6219
It works very well given what it is - but no replacement for a genuine wide lens.
The 3x has some REAL bad press, so I went for the adaptor instead.
www.wildlifeinpixels.com
Andrew M Astbury is offline   Reply With Quote
Old September 1st, 2007, 09:45 AM   #6
It converts it to 2:35:1
