Questions about this back pack at DVinfo.net
Old July 13th, 2007, 10:48 AM   #1
http://www.bhphotovideo.com/c/produc...AW_Camera.html
It could obviously hold everything I need for the A1 and mountain hiking. At only 5.5 pounds it seems good. My problem is it is I believe it is
Linear inches: 50.5"
Which is 4.5" over the standard carry on size. Do you think if its not full i could just squish it down and no one would notice? I would like to use it to bring my camera over to Taiwan, then hike in the mountains with it.
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old July 14th, 2007, 03:56 AM   #2
No protection..I have a petrol backpack also Kata is good..a lot of cushion..and helps hide the camera from thieves.
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply With Quote
Old July 14th, 2007, 10:57 AM   #3
with the space available i think i could add cushioning. I haven`t found a kata or petrol good for hiking, where i don`t have to lay the bag flat on the ground to get the camera out. Do you have pics of your setup? Also I don`t see how having petrol brand name stamped on a bag would turn thieves away, if anything they know you have expensive equipment because of the brand.
Cinematography Site
