Backpack for A1+15" MBP+DSLR
Hey everyone. Sorry to post another "A1 bag" thread, but I did a search and didn't find what I need. I'm looking for a bag that may not even exist, but I was hoping somebody might know of one.
What I'm looking for is a backpack that is: Carry-on (International flight) acceptable size Holds A1+15" MBP+DSLR (1 lens)+accessories (charger, tapes etc.) If such a bag doesn't exist, then at least one that holds the A1+MBP with sufficient protection for light traveling. I can get a hip pouch or something like that for the DSLR. The thing is, I live in Japan and the selection of brands and models here is pretty limited, and the bags in shops are usually sealed so I can't get a good look inside. I can have anything imported, but its hard to get a feel for what is or isn't a good bag just from a small picture on B&H, Amazon etc. so I'm looking for actual owners to report. Thanks! |
jason,
portabrace's bk1 is technically their only "carry-on safe" backpack. it's well-padded and i use one to transport the xha1, 14" laptop, and my 350d w/ a 17-85mm zoom. it's a little tricky getting it all in there, but, after several trips abroad and no broken gear, i've gotten along fine with it. here's a quick snap from the hv20 (little light -- my apologies): http://www.downwiththefuture.com/pictures/xha1_bk1.jpg the bag came with a couple of dividers, but they wouldn't work in this configuration so i pulled them out. i have the dslr disassembled, and the camera body and lens in bubble wrap. i also have a couple of filters in their pouches in between the xha1 mic and xha1 lens to protect the mic from any pressure from the 35mm lens on the other side. laptop is in the bag's front pouch (not showing). there are enough roomy pockets for batteries, cables, chargers, lens wipes, etc., and a pouch on the side for a small tripod/monopod (i would have preferred two extra pockets here instead). it's not a do-all bag, meaning you can't trek around with it and have your camera and xha1 always at the ready, but it does the trick for moving the gear around. |
get the Crumpler zoomiverse. Fit all the things you said and more. Looks like a bag pack too. You can take out the mesh housing with all your gears inside and put it away and use it just like a normal backpack.
life time warranty, water proof, funky looking Last edited by David Chia; July 12th, 2007 at 02:32 PM. |
#4 | |
#5 |
jason, you're exactly right. the xh-a1 is a tight squeeze in the bag. the hood and external mic mount clear the interior depth of the main chamber just a bit, but the padding in the back and up front make for a good, working fit. the main problem for you might be the laptop, as you mentioned. the bulky 15.4" dells will probably not fit, but something slimmer might.
