How do I reduce mic sensitivity? at DVinfo.net
Old June 26th, 2007, 02:18 PM   #1
Hi:
I have currently only the built in mic on the XH A1, how can I reduce sencitivity? Problem is that I will be recording in a very noisy environment, noise/signal will be the same, but last time I tried sound was awful because of too loud recording level.
I have found that I can increase it in the audio setup.
Thanks, Erik
Erik Norgaard is offline   Reply With Quote
Old June 26th, 2007, 02:30 PM   #2
Attenuation
did you try switching the Mic. ATT button below the LCD display. Att stands for Attenuation -- is the reduction in amplitude and intensity of a signal
Kalulu Ngilo is offline   Reply With Quote
Old June 26th, 2007, 02:48 PM   #3
You also can go manual with the levels, and there is a wind noise reduction option in the menu
but you'd probably still have the ATT on regardless
Trish
Trish Kerr is offline   Reply With Quote
Old June 26th, 2007, 02:49 PM   #4
Thanks, looks like that does it.
Erik
Old June 26th, 2007, 02:52 PM   #5
For very high sound level venues, you have to enable MIC ATT, otherwise the input preamps will saturate/clip, even if you adjust the audio level controls or use AGC mode.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
