Phantom Power at DVinfo.net
Old June 25th, 2007, 09:08 AM   #1
Phantom Power
I dont want to sound like an idiot but i cant get my phantom power to work. i have a shotgun plugged in to the XLR port and i have the +48z power on. But the mic doesnt want to work until i put a battery in it. am i doing something wrong?
Do or do not, there is no try...
Mike Redding is offline   Reply With Quote
Old June 25th, 2007, 11:52 AM   #2
If it work with batteries is not a cable problem.
Did you go to the menu and activate the XLR input?
Page 43 of the manual
in the menu
1)Open the menu AUDIO SETUP
2) select XLR INPUT / ON
on camera
3) plug the mic in the CH1 XLR - input channel switch to CH1
4) Line/Mic switch to MIC
5) set the 48v of CH1 to on
now should work
Manuel Fantoni is offline   Reply With Quote
Old June 25th, 2007, 01:45 PM   #3
Hi Mike
Not sure if Manuel is trying to say the same as me.. but check that your cable is wired to power the mic...
I had this problem when I first got my Z1... the short cheap curly wired xlr cable I was using only had two wires connected.. so the mic wouldn't work with out batteries. I then checked with a longer 5m balanced Neutrik cable and it worked fine..
may be your problem to.
regards
Gareth
Gareth Watkins is offline   Reply With Quote
Old June 25th, 2007, 02:18 PM   #4
To add a bit of detail,
Connectors and cable wired
Pin 1 -to- pin 1
Pin 2 -to- pin 2
Pin 3 -to- pin 3
Some cables may "lift" (open) the ground, and if the ground is lifted, phantom power will not work.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
