Outdoor Concert Preset Help Quick! at DVinfo.net
Old June 22nd, 2007, 04:28 PM   #1
On Sunday, which is in two days, I will be shooting an outdoor music concert. I have an A1 for the 1st camera and I will also have a Canon ZR200 for a 2nd camera. The forecast is for all sun with very little cloud cover. What PRESET should I use so that I can accurately match the footage in post?
Kevin | www.kraentertainment.com
A picture is worth 1,000 words | A 2 hour film at 24fps is worth 172,800,000 words
Kevin Amundson is offline   Reply With Quote
Old June 23rd, 2007, 07:47 AM   #2
I don't know about the presets,
However I have found that the neutral density set to the low position (1/32) and about -2.0 on AE will handle most of the light situation on a bright sunny day. Then if you hit a dark environment like a shadow area just hit exposure lock and use the iris to brighten it up.
Bill in Ohio
Bill Ritter is offline   Reply With Quote
Old June 23rd, 2007, 09:23 AM   #3
To "accurately match" those two cams you'll need to use Preset 11.
Eric Weiss is offline   Reply With Quote
Old June 25th, 2007, 07:12 AM   #4
Thanks guys. The second camera didn't make it so all I had was my A1, but I made it through OK.
