Digitalize VHS via XH-A1 possible? at DVinfo.net
Old June 2nd, 2007, 08:48 AM   #1
hi,
a bit off-topic but maybe you can help me. I just thought I might be able to digitalize some of my VHS tapes via XH-A1 to my computer. is it possible and what would I need? thanks for your help.
best rob
Robert Hartmann is offline   Reply With Quote
Old June 2nd, 2007, 09:47 AM   #2
Haven't tried it myself, but page 105 of my manual mentions "Converting Analog Signals into Digital Signals (Analog-Digital Converter)".
Rene Roslev is offline   Reply With Quote
Old June 2nd, 2007, 10:42 AM   #3
As long as they are not copy protected.
dpalomaki@dspalomaki.com
Old June 3rd, 2007, 02:45 AM   #4
i've used my xl2 as a converter, i'll bet you can use the a1...
worst case scenario: plug your vhs deck into the analog video input, and record using your a1, then dump your recorded tape the usual way via firewire...
best case scenario: plug vcr into camera's analog video input, hookup camera to computer via firewire, open a1 menu >signal setup>select [AV-DV] and turn it to 'ON'>close menu, capture... (never tried - should work)
good luck,
Lonnie
Lonnie Bell
mamas boy productions
Las Vegas, NV
Lonnie Bell is offline   Reply With Quote
Old June 3rd, 2007, 02:47 AM   #5
You can I've done it, but you have to set the camera to SD not HDV.
James Miller is offline   Reply With Quote
Old June 9th, 2007, 03:33 AM   #6
thanks guys. works as a charm!
Old October 13th, 2008, 01:33 PM   #7
hmm... I want to record VHS video from my VCR to the a dv tape. I can connect my VCR to my camcorder and when I switch to AV-> DV, I can see the video on my camcorder screen. But I can't record to the tape I've put in there. At best, I can see it go into a record pause mode, but I don't think it's actually recording. Any thoughts?
Current Audio Equipment: two AT822 mics, Sony MZ-RH1, and KE-110CCR. What else should I get for short films and recording stand-up comedy? http://is.gd/kePy
Shahryar Rizvi is offline   Reply
