Matching the A1 with a PD150 at DVinfo.net
Old May 21st, 2007, 09:21 PM   #1
Aside from the obvious of shooting 4:3, 60i does anyone have some input on matching these 2 cameras?
Old May 21st, 2007, 09:26 PM   #2
get 2 decent production monitors-set them to bars, plug the 2 cams in and go from there. There are no cookie cutter settings that I've heard of to match those 2 cams so monitors are the best way to good AFAIK.
Don
Old May 22nd, 2007, 06:11 AM   #3
That would be the way to go alright, but unfortunately it won't be possible
Old May 22nd, 2007, 07:07 AM   #4
Well if you can't use production monitors then how about a couple of TVs-again set to bars and then adjust the cams. At least it would be close.
Hopefully.
Don
Old May 22nd, 2007, 07:24 AM   #5
My standard reply.... The only way to fully match two different cameras is to Chart both cameras and use a waveform monitor and a vector scope!
By using two monitors to try and eyeball the cameras,
you could tweak for days and still not get them to match.
Old May 23rd, 2007, 02:21 AM   #6
I think you might want to set the pd150 to fake 16/9 -- it will actually be fairly decent, and it plays to the A1's strength too
Barry Richard is offline   Reply With Quote
Old May 23rd, 2007, 03:23 AM   #7
Last edited by Uli Mors; May 23rd, 2007 at 01:40 PM. Reason: sorry, I posted into the wrong thread...cant delete.
Uli Mors is offline   Reply With Quote
Old May 24th, 2007, 03:10 AM   #8
Let me know if you are successful. I may need to match my A1 to a VX2100 for a ballet shoot.
After years of lurking, I finally made the mistake of opening my mouth.
Doug Lange is offline   Reply
