XH-A1 Aspect Ratio at DVinfo.net
Old May 12th, 2007, 12:26 PM   #1
XH-A1 Aspect Ratio
Hey. I've been looking at a lot of the footage from the XH-A1 and I noticed a lot of the footage, especially from Steve and Marlon Torres have a (I'm guessing) 2.39:1 aspect ratio (like that of film). I was wondering if the XH-A1 can shoot in that aspect ratio or if that's something done in post.
I should be getting it within the next week. Yay graduation presents! XD
Jerrod Cordell is offline   Reply With Quote
Old May 12th, 2007, 03:21 PM   #2
Here is how I understand film aspect ratios(please correct me if I'm wrong):
There are basically two different filming methods the first is filmed as FLAT. This has an aspect ratio of 1.85:1 almost the same as 1.78:1(16x9).
The second is using the FLAT film with an anamorphic lens which will create an aspect ratio of 2.38:1-2.44:1, but the top and bottom of the frames touch each other so they apply a mask that crops it down to 2.35:1.
THE FINAL OUTPUT IS 2.35:1
OK! Know to answer your question.
The A1 has aspect ratio guides that will display on the LCD for 2.35:1. Your A1 will record the entire screen so you will need to apply a mask in post.
I have some downloadable masks here:
http://www.kraentertainment.com/free.html
Kevin | www.kraentertainment.com
A picture is worth 1,000 words | A 2 hour film at 24fps is worth 172,800,000 words
Kevin Amundson is offline   Reply With Quote
Old May 13th, 2007, 10:14 AM   #3
Thanks man. This is just what I was looking for.
Old May 13th, 2007, 10:36 AM   #4
There have been many different aspect ratios in film over the years depending on the format used.
For Example... 1.33:1, 1.37:1, 1.43:1, 1.85:1, 2.00:1, 2.2:1, 2.39:1, to name a few.
When I shot film, the aspect ratio was usually determined by the film gate I used in the camera.
Old May 13th, 2007, 07:59 PM   #5
That is correct, I was just talking about to two most common used today.
Jerrod, if you want to learn about different film formats Widescreenmuseum.com is a great source of information.
Here's a link to the Main Lobby: http://www.widescreenmuseum.com/widescreen/lobby.htm
And here's a link to the aspect ratios page: http://www.widescreenmuseum.com/wide...spectratio.htm
