Bottom line flickers! It's driving me crazy - Page 2 at DVinfo.net
Old May 7th, 2007, 10:22 PM   #16
still nothing
I've still found nothing that helps the situation. I ended up just placing a mask over the footage on the top and bottom and re rendering. That took it away.
Josh Green is offline   Reply With Quote
Old May 9th, 2007, 03:44 AM   #17
not an ideal solution. I've posted on another forum to see if anyone can come up with anything.
Martin Trotter is offline   Reply With Quote
Old May 9th, 2007, 04:30 AM   #18
It may seem like a strange question, but what sort of monitor do you have? CRT of TFT?
Just because a good friend had similar problems with capturing. His CRT had a very strong magnetic field and that caused several problems during capturing. It also could be another device what does the same.
Who knows....
Gert Kracht is offline   Reply With Quote
Old May 9th, 2007, 04:44 AM   #19
mine is a rather large CRT. I would doubt it, but you never know. Never had any trouble with previous camera.
Old May 9th, 2007, 06:17 AM   #20
a reply from another board - what do you think?:
Here's what I see when we shoot 16x9 from a Digibeta.
The top scanline actually starts slightly less than half a scanline in. The bottom ends half a scanline out. You can see this when you examine the picture on a field monitor with underscan active.
Sort of like:
... etc ...
Normally these half scanlines are out of the visible picture area but you can see them on a 4x3 monitor with the 16x9 aspect ratio enabled.
If I use FCP to slow down this footage with field blending on, it interpolates these half fields with their blank siblings and produces a flicker in the usually black part of the scanline.
Take a close look at your footage and see if you have similar half scanlines at the beginning and end of your video frames.
As I say, if we are going back out to a proper widescreen display, these half scanlines would usually be out of the visible area and not a problem, however if we are letterboxing they are brought back into view.
Added to this, DV uses a different field order from nearly everything else and I think FCP now automatically moves it up (or down) a field to conform it which might produce this flicker at the bottom rather than at the top and the bottom.
Obviously, different cameras and we're in PAL land so your milage will surely vary.
My solution is to crop off the top and bottom scanline.
Old May 9th, 2007, 07:24 AM   #21
I am seeing something similar in Vegas. Actually there are two problems, which may be related.
When I play back 16x9 24F SD footage from the tape, the video looks perfect on my JVC CRT monitor, using an S-Video connection. It even works when I play it back from an old Sony TRV50 and not the A1, which surprised me as the Sony is neither 16x9 nor 24p, much less 24F.
Problem 1:
However, playback of the same footage in Vegas causes the bottom line of video to flicker annoyingly. I noticed it doesn't happen all the time- there is one clip where there's no problem, but then 75% of the way into the clip the flickering begins. Other clips have the problem all the time, and none are completely free of this problem.
Problem 2:
When I watch this footage play back on the LCD screen of my A1, the aspect ratio crazily jumps back and forth from 16:9 and 4:3 every several frames. Unwatchable. The Sony's LCD would do this too, but then pass a near perfect image through its S-Video out to my JVC studio monitor (near perfect because it shows Problem 1 as above).
I'm sure I'm doing something absurdly wrong, as I'm new to Vegas, 24p pulldown and the A1. Here's a list of the facts:
-16x9, 24F, SD, 2:3 pulldown mode A1 footage, captured by Sony TRV50.
-Vegas Project:
NTSC DV 24p Widescreen (720x480, 23.976 fps)
Frame Rate 23.976
"Allow Pulldown Removal when opening 24p DV" is checked
-Footage in Vegas Timeline doesn't show as 24 fps
-Footage looks fine when played back on CRT computer monitor, neither problem 1 or 2 showing
Can anyone help? It seems the A1 isn't causing the problems; as stated above the footage plays back clean from the tape. So, Firewire? I'm kinda lost.
Ben Hayflick is offline   Reply With Quote
Old May 9th, 2007, 10:00 AM   #22
Disjecta
I see this same phenomenon while watching some SD TV broadcasts on an HD monitor.
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old May 9th, 2007, 12:02 PM   #23
I have noticed the problem many times with letterboxed video transfers from super16 film - so obviously the camera isn't an issue - as suggested, try lots of different TVs just to satisfy yourself...
Steve Rosen is offline   Reply With Quote
Old May 9th, 2007, 01:34 PM   #24
Just for once....try to put distance between the camera and the monitor as much as possible.
You could end up putting the camera on the ground, a chair of something else.
Maybe the old camera was a bit more shielded than the A1.
At least, trying does not hurt and who knows....
Old May 17th, 2007, 06:09 PM   #25
Hey Martin
Hey Martin, I figured out a fix for the bottom line flicker. I was capturing in NTSC DV anamorphic but my sequence timeline was set to just NTSC. On my latest project, I captured in anamorphic and set my sequence to anamorphic and by golly when I sent it through to DVDSP and authored the DVD, the bottom line flicker was gone. Maybe this will help you.
Old May 21st, 2007, 11:56 AM   #26
never mind
Never mind, the flicker is still there. I'm on a new project now and it's there and clear as day. It's bastardly!
